[mapserver-users] Python Mapscript MS 3.6.1
Vinko Vrsalovic
vinko at cprsig.cl
Thu Jul 11 05:01:30 EDT 2002
On Thu, Jul 11, 2002 at 10:22:46AM +0200, Michael Schulz wrote:
> Dear List,
> i am also stuck in compiling python mapscript. I use swig 1.1 and mapserver 3.6.0
> (problem?)
> I changed the mapscript.i file according to the mail from Sean, but to no avail. When
> compiling I still get following errors:
> mapscript_wrap.c: In function `_wrap_imageObj_free':
> mapscript_wrap.c:4926: parse error before `*'
> mapscript_wrap.c:4927: `ms_error' undeclared (first use in this function)
> Hmm, Vinko, could you send your mapscript.i file? Or anybody got a clue why it isn't
> working?
Humm, I don't know what happens in 3.6.0, but what does the line 4926
looks like?
In any case, i send the mapscript.i corrected for 3.6.1
Hope it helps you.
BTW (i know this is not the place, but taking advantage of the
oppurtunity), has anyone installed mod_python for apache?
starting apache with it makes the following error:
Syntax error on line 20 of /etc/httpd/conf/httpd.conf:
Cannot load /etc/httpd/modules/mod_python.so into server:
/etc/httpd/modules/mod_python.so: undefined symbol: openpty
That's probably because the module isn't liked against libpty, but in
the configure of the mod_python package there's no way to specify the
libs to link against.
(I'm using python 2.2 and the mod_python docs say it'll work 'til
python 2.1)
Vinko Vrsalovic <vinko[|- at -|]cprsig.cl>
http://www.cprsig.cl
// mapscript.i: SWIG interface file for MapServer scripting extension called MapScript.
// language specific initialization
#ifdef SWIGTCL8
%module Mapscript
/* static global copy of Tcl interp */
static Tcl_Interp *SWIG_TCL_INTERP;
%init %{
#ifdef USE_TCL_STUBS
if (Tcl_InitStubs(interp, "8.1", 0) == NULL) {
return TCL_ERROR;
/* save Tcl interp pointer to be used in getImageToVar() */
SWIG_TCL_INTERP = interp;
#endif
#endif
%module mapscript
#include "../../map.h"
#include "../../maptemplate.h"
%include typemaps.i
%include constraints.i
%rename (_class) class;
// grab mapserver declarations to wrap
%include "../../mapprimitive.h"
%include "../../mapshape.h"
%include "../../mapproject.h"
%include "../../map.h"
//%include "../../maperror.h"
%apply Pointer NONNULL { mapObj *map };
%apply Pointer NONNULL { layerObj *layer };
#ifdef SWIGPYTHON
// For Python, errors reported via the ms_error structure are translated
// into RuntimeError exceptions. (Chris Chamberlin <cdc at aracnet.com>)
static void _raise_ms_exception(void) {
char errbuf[256];
errorObj *ms_error = msGetErrorObj();
snprintf(errbuf, 255, "%s: %s %s\n", ms_error->routine, msGetErrorString(ms_error->code), ms_error->message);
_SWIG_exception(SWIG_RuntimeError, errbuf);
#define raise_ms_exception() { _raise_ms_exception(); return NULL; }
%except {
$function
if ( (ms_error->code != MS_NOERR) && (ms_error->code != -1) )
#endif // SWIGPYTHON
// class extensions for mapObj
%addmethods mapObj {
mapObj(char *filename) {
mapObj *map;
if(filename && strlen(filename))
return msLoadMap(filename, NULL);
else { /* create an empty map, no layers etc... */
map = (mapObj *)malloc(sizeof(mapObj));
if(!map) {
msSetError(MS_MEMERR, NULL, "msLoadMap()");
return NULL;
initMap(map);
return map;
~mapObj() {
msFreeMap(self);
layerObj *getLayer(int i) {
if(i >= 0 && i < self->numlayers)
return &(self->layers[i]); /* returns an EXISTING layer */
else
return NULL;
layerObj *getLayerByName(char *name) {
int i;
i = msGetLayerIndex(self, name);
if(i != -1)
else
return NULL;
int addColor(int r, int g, int b) {
return msAddColor(self, r, g, b);
int getSymbolByName(char *name) {
return msGetSymbolIndex(&self->symbolset, name);
void prepareQuery() {
int status;
status = msCalculateScale(self->extent, self->units, self->width, self->height, self->resolution, &self->scale);
if(status != MS_SUCCESS) self->scale = -1; // degenerate extents ok here
imageObj *prepareImage() {
int status;
imageObj *image=NULL;
image = (imageObj *)malloc(sizeof(imageObj));
if(!image) return NULL;
if(self->width == -1 || self->height == -1) {
msSetError(MS_MISCERR, "Image dimensions not specified.", "prepareImage()");
return NULL;
image->bytes = gdImageCreate(self->width, self->height);
if(!image->bytes) {
msSetError(MS_GDERR, "Unable to initialize image.", "prepareImage()");
return NULL;
image->width = self->width;
image->height = self->height;
image->imagepath = image->imageurl = NULL;
if(msLoadPalette(image->bytes, &(self->palette), self->imagecolor) == -1)
return NULL;
self->cellsize = msAdjustExtent(&(self->extent), self->width, self->height);
return NULL;
return image;
imageObj *draw() {
image->bytes = msDrawMap(self);
image->width = gdImageSX(image->bytes);
image->height = gdImageSY(image->bytes);
return image;
imageObj *drawQuery() {
image->bytes = msDrawQueryMap(self);
return image;
imageObj *drawLegend() {
image->bytes = msDrawLegend(self);
return image;
imageObj *drawScalebar() {
image->bytes = msDrawScalebar(self);
return image;
imageObj *drawReferenceMap() {
image->bytes = msDrawReferenceMap(self);
return image;
int embedScalebar(imageObj *image) {
return msEmbedScalebar(self, image->bytes);
int embedLegend(imageObj *image) {
return msEmbedLegend(self, image->bytes);
int drawLabelCache(imageObj *image) {
return msDrawLabelCache(image->bytes, self);
int getImageToVar(imageObj *image, char *varname) {
// set a scripting language variable by name with image data
int size = 0;
unsigned char *imgbytes;
// Tcl implementation to define needed variables, initialization
#ifdef SWIGTCL8
Tcl_Obj *imgobj;
int flags = TCL_LEAVE_ERR_MSG;
/* no other initialization needed */
#endif
// Perl implementation to define needed variables, initialization
#ifdef SWIGPERL
#endif
// Python implementation to define needed variables, initialization
#ifdef SWIGPYTHON
#endif
// generic code to get imgbytes, size
switch (self->imagetype) {
case(MS_GIF):
#ifdef USE_GD_GIF
// GD /w gif doesn't have gdImageGifPtr()
msSetError(MS_MISCERR, "GIF output is not available.",
"getImageToVar()");
return(MS_FAILURE);
#endif
break;
case(MS_PNG):
#ifdef USE_GD_PNG
imgbytes = gdImagePngPtr(image->bytes, &size);
#else
msSetError(MS_MISCERR, "PNG output is not available.",
"getImageToVar()");
return(MS_FAILURE);
#endif
break;
case(MS_JPEG):
#ifdef USE_GD_JPEG
imgbytes = gdImageJpegPtr(image->bytes, &size, self->imagequality);
#else
msSetError(MS_MISCERR, "JPEG output is not available.",
"getImageToVar()");
return(MS_FAILURE);
#endif
break;
case(MS_WBMP):
#ifdef USE_GD_WBMP
imgbytes = gdImageWBMPPtr(image->bytes, &size, 1);
#else
msSetError(MS_MISCERR, "WBMP output is not available.",
"getImageToVar()");
return(MS_FAILURE);
#endif
break;
default:
msSetError(MS_MISCERR, "Unknown output image type.",
"getImageToVar()");
return(MS_FAILURE);
// Tcl implementation to set variable
#ifdef SWIGTCL8
imgobj = Tcl_NewByteArrayObj(imgbytes, size);
Tcl_IncrRefCount(imgobj);
Tcl_SetVar2Ex(SWIG_TCL_INTERP, varname, (char *)NULL, imgobj, flags);
Tcl_DecrRefCount(imgobj);
gdFree(imgbytes);
return MS_SUCCESS;
#endif
// Perl implementation to set variable
#ifdef SWIGPERL
#endif
// Python implementation to set variable
#ifdef SWIGPYTHON
#endif
// return failure for unsupported swig languages
msSetError(MS_MISCERR, "Unsupported scripting language.",
"getImageToVar()");
return MS_FAILURE;
labelCacheMemberObj *nextLabel() {
static int i=0;
if(i<self->labelcache.numlabels)
return &(self->labelcache.labels[i++]);
else
return NULL;
int queryByPoint(pointObj *point, int mode, double buffer) {
return msQueryByPoint(self, -1, mode, *point, buffer);
int queryByRect(rectObj rect) {
return msQueryByRect(self, -1, rect);
int queryByFeatures(int slayer) {
return msQueryByFeatures(self, -1, slayer);
int queryByShape(shapeObj *shape) {
return msQueryByShape(self, -1, shape);
int setWKTProjection(char *string) {
return msLoadWKTProjectionString(string, &(self->projection));
%new char *getProjection() {
return msGetProjectionString(&(self->projection));
int setProjection(char *string) {
return msLoadProjectionString(&(self->projection), string);
int save(char *filename) {
return msSaveMap(self, filename);
int saveQuery(char *filename) {
return msSaveQuery(self, filename);
int saveQueryAsGML(char *filename) {
return msGMLWriteQuery(self, filename);
char *getMetaData(char *name) {
return(msLookupHashTable(self->web.metadata, name));
int setMetaData(char *name, char *value) {
if (!self->web.metadata)
self->web.metadata = msCreateHashTable();
if (msInsertHashTable(self->web.metadata, name, value) == NULL)
return MS_FAILURE;
return MS_SUCCESS;
int setSymbolSet(char *szFileName)
msFreeSymbolSet(&self->symbolset);
msInitSymbolSet(&self->symbolset);
// Set symbolset filename
self->symbolset.filename = strdup(szFileName);
// Symbolset shares same fontset as main mapfile
self->symbolset.fontset = &(self->fontset);
return msLoadSymbolSet(&self->symbolset);
int mapObj_getNumSymbols()
return self->symbolset.numsymbols;
int moveLayerup(int layerindex) {
return msMoveLayerUp(self, layerindex);
int moveLayerdown(int layerindex) {
return msMoveLayerDown(self, layerindex);
int *getLayersdrawingOrder() {
return self->layerorder;
int setLayersdrawingOrder(int *panIndexes) {
return msSetLayersdrawingOrder(self, panIndexes);
char *processTemplate(int bGenerateImages, char **names, char **values, int numentries) {
return msProcessTemplate(self, bGenerateImages, names, values, numentries);
char *processLegendTemplate(char **names, char **values, int numentries) {
return msProcessLegendTemplate(self, names, values, numentries);
char *processQueryTemplate(char **names, char **values, int numentries) {
return msProcessQueryTemplate(self, names, values, numentries);
// class extensions for layerObj, always within the context of a map
%addmethods layerObj {
layerObj(mapObj *map) {
if(map->numlayers == MS_MAXLAYERS) // no room
return(NULL);
if(initLayer(&(map->layers[map->numlayers])) == -1)
return(NULL);
map->layers[map->numlayers].index = map->numlayers;
map->layerorder[map->numlayers] = map->numlayers;
map->numlayers++;
return &(map->layers[map->numlayers-1]);
~layerObj() {
return; // map deconstructor takes care of it
int open(char *path) {
int status;
status = msLayerOpen(self, path);
if (status == MS_SUCCESS) {
return msLayerGetItems(self);
return status;
void close() {
msLayerClose(self);
int getShape(shapeObj *shape, int tileindex, int shapeindex) {
return msLayerGetShape(self, shape, tileindex, shapeindex);
resultCacheMemberObj *getResult(int i) {
if(!self->resultcache) return NULL;
if(i >= 0 && i < self->resultcache->numresults)
return &self->resultcache->results[i];
else
return NULL;
classObj *getClass(int i) { // returns an EXISTING class
if(i >= 0 && i < self->numclasses)
return &(self->class[i]);
else
return NULL;
char *getItem(int i) { // returns an EXISTING item
if(i >= 0 && i < self->numitems)
return (self->items[i]);
else
return NULL;
int draw(mapObj *map, imageObj *image) {
return msDrawLayer(map, self, image->bytes);
int drawQuery(mapObj *map, imageObj *image) {
int queryByAttributes(mapObj *map, int mode) {
return msQueryByAttributes(map, self->index, mode);
int queryByPoint(mapObj *map, pointObj *point, int mode, double buffer) {
return msQueryByPoint(map, self->index, mode, *point, buffer);
int queryByRect(mapObj *map, rectObj rect) {
return msQueryByRect(map, self->index, rect);
int queryByFeatures(mapObj *map, int slayer) {
return msQueryByFeatures(map, self->index, slayer);
int queryByShape(mapObj *map, shapeObj *shape) {
return msQueryByShape(map, self->index, shape);
int setFilter(char *string) {
return loadExpressionString(&self->filter, string);
int addFeature(shapeObj *shape) {
self->connectiontype = MS_INLINE; // set explicitly
if(insertFeatureList(&(self->features), shape) == NULL)
return -1;
else
return 0;
return(msLookupHashTable(self->metadata, name));
if (!self->metadata)
self->metadata = msCreateHashTable();
if (msInsertHashTable(self->metadata, name, value) == NULL)
return MS_FAILURE;
return MS_SUCCESS;
// No longer a memory leak, at least with swig 1.3.11. Swig makes a copy
// of the returned string and then free's it.
%new char *getWMSFeatureInfoURL(mapObj *map, int click_x, int click_y, int feature_count, char *info_format) {
return(msWMSGetFeatureInfoURL(map, self, click_x, click_y, feature_count, info_format));
// class extensions for classObj, always within the context of a layer
%addmethods classObj {
classObj(layerObj *layer) {
if(layer->numclasses == MS_MAXCLASSES) // no room
return NULL;
if(initClass(&(layer->class[layer->numclasses])) == -1)
return NULL;
layer->class[layer->numclasses].type = layer->type;
layer->numclasses++;
return &(layer->class[layer->numclasses-1]);
~classObj() {
return; // do nothing, map deconstrutor takes care of it all
int setExpression(char *string) {
return loadExpressionString(&self->expression, string);
int setText(layerObj *layer, char *string) {
return loadExpressionString(&self->text, string);
return MS_FAILURE;
return MS_SUCCESS;
int drawLegendIcon(mapObj *map, layerObj *layer, int width, int height, imageObj *dstImage, int dstX, int dstY) {
return msDrawLegendIcon(map, layer, self, width, height, dstImage->bytes, dstX, dstY);
imageObj *createLegendIcon(mapObj *map, layerObj *layer, int width, int height) {
image->bytes = msCreateLegendIcon(map, layer, self, width, height);
return image;
// class extensions for pointObj, useful many places
%addmethods pointObj {
pointObj() {
return (pointObj *)malloc(sizeof(pointObj));
~pointObj() {
free(self);
int project(projectionObj *in, projectionObj *out) {
return msProjectPoint(in, out, self);
int draw(mapObj *map, layerObj *layer, imageObj *image, int classindex, char *text) {
return msDrawPoint(map, layer, self, image->bytes, classindex, text);
double distanceToPoint(pointObj *point) {
return msDistanceBetweenPoints(self, point);
double distanceToLine(pointObj *a, pointObj *b) {
return msDistanceFromPointToLine(self, a, b);
double distanceToShape(shapeObj *shape) {
switch(shape->type) {
case(MS_SHAPE_POINT):
return msDistanceFromPointToMultipoint(self, &(shape->line[0]));
case(MS_SHAPE_LINE):
return msDistanceFromPointToPolyline(self, shape);
case(MS_SHAPE_POLYGON):
return msDistanceFromPointToPolygon(self, shape);
return -1;
// class extensions for lineObj (eg. a line or group of points), useful many places
%addmethods lineObj {
lineObj() {
lineObj *line;
line = (lineObj *)malloc(sizeof(lineObj));
if(!line)
return(NULL);
line->numpoints=0;
line->point=NULL;
return line;
~lineObj() {
free(self->point);
free(self);
return msProjectLine(in, out, self);
pointObj *get(int i) {
if(i<0 || i>=self->numpoints)
return NULL;
else
return &(self->point[i]);
int add(pointObj *p) {
if(self->numpoints == 0) { /* new */
self->point = (pointObj *)malloc(sizeof(pointObj));
if(!self->point)
return -1;
} else { /* extend array */
self->point = (pointObj *)realloc(self->point, sizeof(pointObj)*(self->numpoints+1));
if(!self->point)
return -1;
self->point[self->numpoints].x = p->x;
self->point[self->numpoints].y = p->y;
self->numpoints++;
return 0;
// class extensions for shapeObj
%addmethods shapeObj {
shapeObj(int type) {
shapeObj *shape;
shape = (shapeObj *)malloc(sizeof(shapeObj));
if(!shape)
return NULL;
msInitShape(shape);
if(type >= 0) shape->type = type;
return shape;
~shapeObj() {
msFreeShape(self);
free(self);
return msProjectShape(in, out, self);
lineObj *get(int i) {
if(i<0 || i>=self->numlines)
return NULL;
else
return &(self->line[i]);
int add(lineObj *line) {
return msAddLine(self, line);
int draw(mapObj *map, layerObj *layer, imageObj *image) {
return msDrawShape(map, layer, self, image->bytes, MS_TRUE);
void setBounds() {
int i, j;
self->bounds.minx = self->bounds.maxx = self->line[0].point[0].x;
self->bounds.miny = self->bounds.maxy = self->line[0].point[0].y;
for( i=0; i<self->numlines; i++ ) {
for( j=0; j<self->line[i].numpoints; j++ ) {
self->bounds.minx = MS_MIN(self->bounds.minx, self->line[i].point[j].x);
self->bounds.maxx = MS_MAX(self->bounds.maxx, self->line[i].point[j].x);
self->bounds.miny = MS_MIN(self->bounds.miny, self->line[i].point[j].y);
self->bounds.maxy = MS_MAX(self->bounds.maxy, self->line[i].point[j].y);
return;
int copy(shapeObj *dest) {
return(msCopyShape(self, dest));
char *getValue(int i) { // returns an EXISTING value
if(i >= 0 && i < self->numvalues)
return (self->values[i]);
else
return NULL;
int contains(pointObj *point) {
if(self->type == MS_SHAPE_POLYGON)
return msIntersectPointPolygon(point, self);
return -1;
int intersects(shapeObj *shape) {
switch(self->type) {
return msIntersectPolylines(self, shape);
return msIntersectPolylinePolygon(self, shape);
break;
return msIntersectPolylinePolygon(shape, self);
return msIntersectPolygons(self, shape);
break;
return -1;
// class extensions for rectObj
%addmethods rectObj {
rectObj() {
rectObj *rect;
rect = (rectObj *)calloc(1, sizeof(rectObj));
if(!rect)
return(NULL);
return(rect);
~rectObj() {
free(self);
return msProjectRect(in, out, self);
double fit(int width, int height) {
return msAdjustExtent(self, width, height);
shapeObj shape;
msInitShape(&shape);
msRectToPolygon(*self, &shape);
shape.classindex = classindex;
shape.text = strdup(text);
msDrawShape(map, layer, &shape, image->bytes, MS_TRUE);
msFreeShape(&shape);
return 0;
// class extensions for shapefileObj
%addmethods shapefileObj {
shapefileObj(char *filename, int type) {
shapefileObj *shapefile;
int status;
shapefile = (shapefileObj *)malloc(sizeof(shapefileObj));
if(!shapefile)
return NULL;
if(type == -1)
status = msSHPOpenFile(shapefile, "rb", NULL, filename);
else if(type == -2)
status = msSHPOpenFile(shapefile, "rb+", NULL, filename);
else
status = msSHPCreateFile(shapefile, filename, type);
if(status == -1) {
msSHPCloseFile(shapefile);
free(shapefile);
return NULL;
return(shapefile);
~shapefileObj() {
msSHPCloseFile(self);
free(self);
int get(int i, shapeObj *shape) {
if(i<0 || i>=self->numshapes)
return -1;
msFreeShape(shape); /* frees all lines and points before re-filling */
msSHPReadShape(self->hSHP, i, shape);
return 0;
int getPoint(int i, pointObj *point) {
return -1;
msSHPReadPoint(self->hSHP, i, point);
return 0;
int getTransformed(mapObj *map, int i, shapeObj *shape) {
return -1;
msTransformShape(shape, map->extent, map->cellsize);
return 0;
void getExtent(int i, rectObj *rect) {
msSHPReadBounds(self->hSHP, i, rect);
int add(shapeObj *shape) {
return msSHPWriteShape(self->hSHP, shape);
int addPoint(pointObj *point) {
return msSHPWritePoint(self->hSHP, point);
// class extensions for imageObj
%addmethods imageObj {
imageObj(int width, int height) {
image->bytes = gdImageCreate(width, height);
image->width = width;
image->height = height;
return(image);
~imageObj() {
gdImageDestroy(self->bytes);
free(self->imagepath);
free(self->imageurl);
free(self);
void free() {
free(self);
void saveImage(char *filename, int type, int transparent, int interlace, int quality) {
msSaveImage(self->bytes, filename, type, transparent, interlace, quality);
// class extensions for projectionObj
%addmethods projectionObj {
projectionObj(char *string) {
int status;
projectionObj *proj=NULL;
proj = (projectionObj *)malloc(sizeof(projectionObj));
if(!proj) return NULL;
msInitProjection(proj);
status = msLoadProjectionString(proj, string);
if(status == -1) {
msFreeProjection(proj);
free(proj);
return NULL;
return proj;
~projectionObj() {
msFreeProjection(self);
free(self);
// class extensions for labelCacheObj - TP mods
%addmethods labelCacheObj {
void freeCache() {
int i;
for (i = 0; i < self->numlabels; i++) {
free(self->labels[i].string);
msFreeShape(self->labels[i].poly);
self->numlabels = 0;
for (i = 0; i < self->nummarkers; i++) {
msFreeShape(self->markers[i].poly);
self->nummarkers = 0;
// class extensions for DBFInfo - TP mods
%addmethods DBFInfo {
char *getFieldName(int iField) {
static char pszFieldName[1000];
int pnWidth;
int pnDecimals;
msDBFGetFieldInfo(self, iField, &pszFieldName[0], &pnWidth, &pnDecimals);
return pszFieldName;
int getFieldWidth(int iField) {
int pnWidth;
int pnDecimals;
return pnWidth;
int getFieldDecimals(int iField) {
int pnWidth;
int pnDecimals;
return pnDecimals;
int getFieldType(int iField) {
return msDBFGetFieldInfo(self, iField, NULL, NULL, NULL);
