[mapserver-users] Python Mapscript MS 3.6.1
Michael Schulz
mschulz at webgis.de
Thu Jul 11 11:49:36 EDT 2002
thanks for the hint to the setup script of Norman Vine. Find it here:
http://www.vso.cape.com/~nhv/files/python/mapscript/setup.py )
You may need to change some things (paths, libs, etc. ).
It works well and python gets swigged and compiled and installed automatically. Yipiie!
But after that i encountered some problems. After invoking python, i can do:
>>>import mapscript (works fine), then i try a test that Norman mentioned in a post:
>>>mapscript.msGetVersion() (should give the MS_VERSION string) but i get this error:
AttributeError: 'mapscript' module has no attribute 'msGetVersion'
>>>m = mapscript.ms_newmapObj('/path/to/mapfile')
File "<stdin>", line 1, in ?
AttributeError: 'mapscript' module has no attribute 'ms_newmapObj'
So, it seems i get mapscript compiled and all, but it is not working properly.
(I am using MS 3.6.0, Python 2.1.2, Swig 1.3.13)
Perhaps someone who has an overview of mapscript/compiling/swig/python can give some advice
where to look for the problem.
Thanks, Michael
Michael Schulz in medias res
Dipl.-Geologe Gesellschaft für
Informationstechnologie mbH
Sautierstr. 38, 79104 Freiburg
0761 55695-95 (Fax 96)
mschulz at webgis.de www.webgis.de
