[mapserver-users] network analysis in mapserver
Roberto Micarelli
mi.ro at iol.it
Mon Jul 15 13:05:52 EDT 2002
On Monday 15 July 2002 16:37, woodbri at swoodbridge.com wrote:
> Seamus,
> Mapserver doesn't have this functionality as you probably know at
> this point. I have code that does what you describe below that could
> be adapted to any number of similar application. To be able to run
> fast (ie for a web application) I build a directed graph that is then
> used to compute the shortest path method and then I extract the
> required segments into a shape file that can be rendered by
> mapserver.
> I have a live demo running on my site at
> http://iMapTools.com/demos
> click the "Get A Route" link
> This demo is using the US National Highway Planning Network
> shapefiles for the directed graph, but a directed graph could be
> built for other networks from shapefiles or other data sources.
Do you build the graph on each invocation or does it stay resident? Did you
write the code for digraph support?
Roberto
