[mapserver-users] network analysis in mapserver
Seamus Thomas Carroll carrolls at unbc.ca
Mon Jul 15 12:11:31 EDT 2002
The site looks very good.  How can I get a copy of the code?
Seamus
On Mon, 15 Jul 2002 woodbri at swoodbridge.com wrote:
> Seamus,
> Mapserver doesn't have this functionality as you probably know at
> this point. I have code that does what you describe below that could
> be adapted to any number of similar application. To be able to run
> fast (ie for a web application) I build a directed graph that is then
> used to compute the shortest path method and then I extract the
> required segments into a shape file that can be rendered by
> mapserver.
> I have a live demo running on my site at
>     http://iMapTools.com/demos
> click the "Get A Route" link
> This demo is using the US National Highway Planning Network
> shapefiles for the directed graph, but a directed graph could be
> built for other networks from shapefiles or other data sources.
> -Stephen Woodbridge
> On 12 Jul 2002 at 9:43, Seamus Thomas Carroll wrote:
> > Hi,
> > I have post GIS installed but I am not currently using it.  I have a road
> > network for British Columbia and some other provinces and two sets of
> > point data.  I need to be able to find the shortest path along from point
> > A (postal code) to point B (hospital data) using an impedance taken from
> > the dbf.  For example, the length in metres for an arc or the amount of
> > time to travel an arc.  I need the total impedance and a shape file
> > representing the path as a result.  Would any of these tools solve this
> > problem for me?
> > Seamus
> > On Fri, 12 Jul 2002, Robert W. Burgholzer wrote:
> > > Seamus,
> > > Are you using postGIS by chance? I am working on a set of tools that
> > > might not be network analysis, but we may have some overlap that we
> > > could share.
> > > I too am seeking independence from esri, and postgres extendability (all
> > > functions can be written in C, or several other languages) seems to me
> > > to be a potential for high quality, open source GIS tools. Already there
> > > are several geo-processing routines out there acting in
> > > postgres/postgis. What type of analysis functions are you looking for?
> > > Rob
