[mapserver-users] PHP-MapScript: saveImage and imagetype
Gerhard Schimon
gs at wigeogis.at
Thu Jul 18 10:17:15 EDT 2002
A few days ago I installed PHP-Mapscript vers. 3.6.2 from
www2.dmsolutions.on.ca
Until then I was working with vers. 3.5
Everything works fine except when using $image->saveImage("", MS_PNG, 0, 0,
40).
The output alway is a GIF-File, no matter what imagetype I use.
I also changed the IMAGETYPE-Value in the .map-file -> no change.
My System is Windows2000 and phpinfo() says:
MapScript Version ($Revision: 1.104.2.4 $ $Date: 2002/07/08 20:04:58 $)
MapServer version 3.6.2 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP
SUPPORTS=PROJ SUPPORTS=TTF SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLIENT
INPUT=EPPL7 INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE
What can I do to change the output-type?
Thanks
Gerhard
Ing. Gerhard SCHIMON
WIGeoGIS GmbH
Hansalgasse 3
A-1030 Wien, Austria
Tel.: +43-1-7151987-22
Fax: +43-1-7151987-99
E-mail: gs at wigeogis.at
Web: http://www.wigeogis.at
WAP: http://wap.wigeogis.at
