[mapserver-users] PHP_mapscript error
woodbri at swoodbridge.com woodbri at swoodbridge.com
Mon Jul 22 23:00:01 EDT 2002
Nyon,
I hate to ask the obvious question, but have you copied the
php_mapscript_36.dll file to c:\php\extensions/php_mapscript_36.dll
and does it have permissions so that the webserver can access it?
Run a php script
<?php
phpinfo();
where is php_mapscript_36.dll loaded on the production server?
where does it say the php.ini file is located at?
where does it say the extensions dir is located at?
When you run your php script that uses mapscript is there a path on
the dl("php_mapscript_36.dll"); line?
Hope this helps,
  -Steve
On 23 Jul 2002 at 10:24, YC Nyon wrote:
> i already done up a PHP ms application on my production server and are in
> the process of porting it to my data centre server.
> however, i got this error message
> Warning: Unable to load dynamic library
> 'c:\php\extensions/php_mapscript_36.dll' - The specified module could not be
> found. in C:\Web\GPS_spot\gpsmap.php on line 116
> i am using PHP-ms 3.6 and php 4.1.2 on Windows 2000 AS. also in the php.ini
> file, the extension dir is c:\php\extensions
> it's works fine in the production server.
> also i commented out the extension ;extension=php_mapscript_36.dll
> php doesn't work if i uncomment it.
> Nyon
