[mapserver-users] Seamless Layers in MapServer
woodbri at swoodbridge.com
Thu Jul 25 10:56:28 EDT 2002
Or in the case of something like Census Tiger/Line data I have 3000+
counties and each county has roads, landmarks, various boundary
files, lakes, rivers, etc. I create a tileindex to treat them all as
one continuous layer for each data class. So for example I can have
one LAYER which will define roads across the whole US and one for
rivers, etc.
I can combine this with Ed's suggest below of using groups and if I
need 4-5 LAYERs to define roads at different scales I can GROUP them
so I can turn ON/OFF all road related LAYERs in 3000+ counties as if
it was one LAYER.
-Steve
On 25 Jul 2002 at 8:48, Ed McNierney wrote:
> Reddy -
> I'm not familiar with the details of MapInfo's "seamless layers" but you can produce a similar effect using the GROUP statement in MapServer. You can assign multiple layers to the same GROUP and then refer to that group by name as if it were a single layer.
> - Ed
> Ed McNierney
> President and Chief Mapmaker
> TopoZone.com / Maps a la carte, Inc.
> 73 Princeton Street, Suite 305
> North Chelmsford, MA 01863
> ed at topozone.com
> (978) 251-4242
> -----Original Message-----
> From: Reddy Srinivas [mailto:Reddy at corp.sunday.com]
> Sent: Thursday, July 25, 2002 2:45 AM
> To: 'mapserver-users at lists.gis.umn.edu'
> Subject: [mapserver-users] Seamless Layers in MapServer
> Hi,
> In MapInfo there is a concept called the "Seamless Layers" where you can
> create a single layer making use of more than one layer. Is there a similar
> kind of concept available in MapServer. I don't have much idea about
> mapserver as these are my first days with it.
> How do I write the code in .MAP file to tell the Server that these bunch of
> section make one layer.
> Any suggestions, ideas, help??
> Thanks a lot.
> > Reddy.
