[mapserver-users] Problem with truetype labelling in php mapscript
Dylan Rawlins
dylan at brc21.co.za
Fri Jul 26 05:16:37 EDT 2002
I experienced a problem in displaying truetype labels under php
mapscript 3.5 and was advised to upgrade to 3.6.1. We have now
upgraded but are experiencing the same problem. By changing the
labels to bitmaps the system works perfectly so we have narrowed
the problem down to the Freetype compilation.
We are experiencing difficulties in installing the older freetype
libraries on the server (as described in
http://mapserver.gis.umn.edu/cgi-bin/wiki.pl?PHPMapScriptRH72):
.. edit Makefile to compile with Freetype1... Mapscript seems to
have problem loading fonts when using gd compiled with Freetype2
on RH7.x ...
Our current server configuration is as follows:
Linux version 2.4.9-31
Red Hat Linux release 7.1 (Seawolf)
Apache/1.3.19 (Unix)
PHP/4.2.1 and PHP/4.0.6 (used by Ensim)
freetype-2.0.1-4
gd-1.8.3-7
Installing the older gd and freetype1 libraries is causing
dependencies problems with our existing PHP installation (not only
PHP 4.2.1, but also PHP 4.0.6 which is being used by the Ensim
control panel).
I've also found the following:
http://mapserver.gis.umn.edu/doc/phpmapscript-install-howto.html
Q: Why can't both PHP and MapScript be compiled with Freetype
support?
A: You cannot have Freetype enabled in both PHP and MapServer
because of a conflict with the gdttf.c and gdcache.c files that are
included in both PHP and MapServer but are not identical. We may
try to fix that conflict in the future, but in the meantime, one of PHP
or MapServer has to be compiled using --without-ttf. This is
especially important with PHP4 because it includes TTF support by
default.
This brings us back to the fact that Mapscript/Mapserver does not
seem to be simple to install when it is used in conjunction with
PHP 4.x on a Linux server.
So it seems that Mapscript does not work with Freetype2, is this
correct? Any advice on what I can do to enable Truetype labelling?
Many thanks
Dylan
