[mapserver-users] editing shp files
David Turover
dturover at student.santarosa.edu
Tue Jul 30 11:01:49 EDT 2002
On Tue, 30 Jul 2002, Lowell.Filak wrote:
> I can quickly see two possibilities:
> 1) Create an index on the shapefile and things may speed up to an
> acceptable pace.
I hadn't heard of indexing shape files before, so I did a little googling
and in the process found a doc which explains the makeup of shapefiles
better than I did in a prior post:
http://www.uiowa.edu/~osa/gisatosa/howto/filetypes.html
I've also seen .prj files (projection) and .shp.xml (XML formatted
metadata about your shapefile), which aren't mentioned on this page.
I don't think mapserver has support for sbn/sbx/ain/aih files, although I
would love to be corrected.
