SV: [mapserver-users] Mapserver crashing
Paul Ramsey pramsey at refractions.net
Wed Jul 31 12:50:31 EDT 2002
Try using a lower-case 'epsg'.
Anders Knudstrup Hansen LE34 wrote:
> Thanks for the quick reply.... Actually I have the EPSG line commented out in my mapfile....
> I do however have EPSG codes in my layers....
> For example:
> layer
>  NAME "Zoner"
>  TYPE polygon
>  STATUS default
>  connectiontype ogr
>  connection "data/tab/Positive_30-07-2002_21_50.TAB"
>  class
>   symbol "skrav"
>   color 255 0 0
>   size 3
>   outlinecolor 255 0 0
>   name "3 km. zoner"
>  end
>  projection
>   "init=EPSG:32632"
>  END
> end
> As far as I have understood I'm supposed to tell mapserver what projection each layer is????
> / Anders
> > -----Oprindelig meddelelse-----
> > Fra: Steve Lime [mailto:steve.lime at dnr.state.mn.us]
> > Sendt: 31. juli 2002 17:29
> > Til: Anders Knudstrup Hansen LE34; mapserver-users at lists.gis.umn.edu
> > Emne: Re: [mapserver-users] Mapserver crashing
> > I'm wondering if the fact that your defining 2 projections: 1 with the
> > EPSG code and another below that could have anything to do with it.
> > Steve
> > Stephen Lime
> > Data & Applications Manager
> > Minnesota DNR
> > 500 Lafayette Road
> > St. Paul, MN 55155
> > 651-297-2937
> > >>> "Anders Knudstrup Hansen LE34" <akh at le34.dk> 07/31/02 10:06AM >>>
> > Hello again...
> > I'm having trouble with the projection object....
> > Below is what I have in my map file, but mapserver crashes everytime i
> > try to access the map???
> > projection
> > "init=EPSG:23032"
> > "proj=utm"
> > "ellps=intl"
> > "zone=32"
> > "north"
> > "no_defs"
> > END
> > As I understand this version of mapserver should support proj etc.
> > X:\Programmer\Apache Group\Apache\cgi-bin>mapserv -v
> > MapServer version 3.6.1 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP
> > SUPPORTS=P
> > ROJ SUPPORTS=TTF SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLIENT INPUT=EPPL7
> > INPUT=POSTG
> > IS INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE
> > Anybody got any ideas?????
> > / Anders
      __
     | Paul Ramsey
     | Refractions Research
     | Email: pramsey at refractions.net
     | Phone: (250) 885-0632
     \_
