[mapserver-users] Easy Mapserver demo (was: New User)
Fawcett, David
david.fawcett at moea.state.mn.us
Mon Jun 3 10:28:17 EDT 2002
A year or two back, someone had mentioned using Sambar Server to run a MapServer App off a CD.
I used it to set up a couple of Mapserver 3.3 demo apps. Worked quite slick.
http://www.sambar.com/
David.
David J. Fawcett
GIS / Databases
MN Office of Environmental Assistance
520 Lafayette Rd N
St. Paul, MN 55155
651.215.0200
> From: Tyler Mitchell[SMTP:TMitchell at lignum.com]
> Sent: Friday, May 31, 2002 10:45 AM
> To: mapserver-users at lists.gis.umn.edu
> Subject: [mapserver-users] Easy Mapserver demo (was: New User)
> <<File: InterScan_Disclaimer.txt>>
> A while back I had demoed a program that was a mini web server that could
> run straight off a cdrom. It included CGI support. Does this ring a bell
> with you? I'm trying to find this program again - any suggestions?
> I'd like to work with others to get Mapserver and related technologies
> working in such an environment for demostration purposes. Have you done
> any work on this sort of thing?
> Drop me if this sounds good to you or if you have any pointers for me.
> Tyler
> "Simon Kirkness"
> <Simon.Kirkness at fisheries.ns To: <mapserver-users at lists.gis.umn.edu>
> w.gov.au> cc:
> Sent by: Fax to:
> owner-mapserver-users at lists. Subject: [mapserver-users] New User
> gis.umn.edu
> 05/29/2002 05:41 PM
> Hi All,
> Am I able to run the MapServer application and Demo on a PC independant
> of a web server?
> Simon Kirkness
> NSW Fisheries
> Project Officer
> Threatened Species
> Port Stephens Fisheries Centre
> Ph: (02) 4916 3810
> Fax: (02) 4916 3880
> Email: kirkness at fisheries.nsw.gov.au
> Note: This message is intended for the addressee named and may contain
> confidential information. If you are not the intended recipient,
> please
> delete it and notify the sender. Views expressed in this message are
> those
> of the individual sender, and are not necessarily the views of NSW
> Fisheries.
> (See attached file: InterScan_Disclaimer.txt)
