[mapserver-users] shapeObj mapscript comments
Michael Schulz
mschulz at webgis.de
Tue Jun 4 11:02:34 EDT 2002
i think you can set the class_index of a shapeObj like this (php-syntax):
$Shapeobj->set("classindex", $your_classindex_int);
HTH, Michael
imap at chesapeake.net schrieb:
> ok guys... using perl mapscript, still trying to fix
> a bunch of broken code after going to mapserv3.5,
> somewhere along the line
> shapeObj->draw(mapObj,layerObj,image,integer class_index,character text)
> changed to
> shapeObj->draw(mapObj,layerObj,image)
> My question here is... How do you classify the shape based on the classes
> defined for layerObj? the shapeObj->draw() method is missing attributes,
> so any clue how to get around this?
> Regards,
> Chris Stuber (mapsurfer)
> Silicon Mapping Solutions
Michael Schulz in medias res
Dipl.-Geologe Gesellschaft für
Informationstechnologie mbH
Sautierstr. 38, 79104 Freiburg
0761 55695-95 (Fax 96)
mschulz at webgis.de www.webgis.de
