[mapserver-users] WMS Client Support
Brian Fischer bfischer at mpls.houstoneng.com
Tue Jun 4 12:57:52 EDT 2002
Thanks Debbie.  I now see the image in my web browser via the connection
string
(http://www2.dmsolutions.ca/cgi-bin/mswms_gmap?VERSION=1.1.0&REQUEST=get
MAP&LAYERS=bathymetry,prov_bound,drain_fn&FORMAT=image/gif), but I still
don't get the image in my MapServer application.  I think my problem may
be related to projections, because I don't get any error messages.  It
almost seems like I may be getting a blank image from the WMS server.  I
see my other layers in the mapfile, but not the WMS layer.  How are
projections handled via the WMS Client Support?
I am trying to get DMSolutions Elevation/Bathymetry data to display.
According to the getCapabilities from that WMS Server the data is in
EPSG:42304.  I essentially want the data to be projected to EPSG:4269
(NAD83 DD).  Here is my mapfile: Am I using the projections incorrectly?
Or is there something else I am missing in my mapfile or connection
string?
Thanks,
Brian
#Mapfile
# RRBDINviewer.map
MAP
   NAME "RRBDINViewer"
   EXTENT -104.057243 42.47964 -89.179642 59.99992
   SIZE  500 400
   FONTSET "d:/rrbdin_dev/tools/mapserv35/fonts/fontset.list"
   SYMBOLSET "d:/rrbdin_dev/tools/mapserv35/symbols/symbol.sym"
   SHAPEPATH "d:/rrbdin_dev/tools/mapviewer/shapefiles/dd"
   UNITS DD
   Projection
     "init=epsg:4269"
   END
   WEB
      IMAGEPATH "d:/rrbdin_dev/tools/mapserv35/temp_mapserv/"
      TEMPLATE rrbdinviewer.html
    #  MAXSCALE 7000000
   END
   LEGEND
      STATUS ON
      IMAGECOLOR 204 204 153
      LABEL
         TYPE TRUETYPE
         ANTIALIAS TRUE
         FONT arial
         COLOR 0 0 0
         SIZE 9
      END
   END
   SCALEBAR
      STATUS ON
      INTERVALS 4
      SIZE 150 6
      OUTLINECOLOR 120 120 120
      COLOR 0 0 0
      BACKGROUNDCOLOR 204 204 153
      STYLE 1
      UNITS MILES
      LABEL
         ANTIALIAS TRUE
         COLOR 0 0 0
         SIZE tiny
      END
   END #scalebar
   REFERENCE
      STATUS ON
      IMAGE "d:/rrbdin_dev/tools/mapviewer/images/rrb_refmap.gif"
      SIZE 150 153
      COLOR -1 -1 -1
      OUTLINECOLOR 255 0 0
   END #reference
LAYER
  NAME bathmetry
  METADATA
      "wms_title" "Elevation/Bathymetry"
      "wms_srs" "EPSG:42304 EPSG:42101 EPSG:4269 EPSG:4326"
      "wms_connectiontimeout" "60"
  END
  TYPE RASTER
  STATUS ON
  CONNECTION
"http://www2.dmsolutions.ca/cgi-bin/mswms_gmap?VERSION=1.1.0&REQUEST=get
MAP&LAYERS=bathymetry,prov_bound,drain_fn&FORMAT=image/gif"
  CONNECTIONTYPE WMS
  PROJECTION
      "init=epsg:42304"
  END
End #layer DmSolutions
LAYER
      NAME pol_bndry
      DATA "pol_bnd"
      STATUS DEFAULT
      TYPE LINE
      PROJECTION
      "init=epsg:4269"
      END
      LABELITEM "NAME"
      LABELMINSCALE 2000000
      CLASS
         NAME "Political Boundary"
         COLOR 50 50 50
         SYMBOL 2
         LABEL
          FORCE TRUE
          SIZE 12
          COLOR 50 50 50
          OUTLINECOLOR 200 200 200
          BUFFER 4
          TYPE TRUETYPE
          FONT arial-bold
          ANTIALIAS TRUE
        END
      END
   END
LAYER
      NAME watershed
      DATA "envirocanada_wtrshd"
      STATUS DEFAULT
      TYPE LINE
      PROJECTION
      "init=epsg:4269"
      END
      CLASS
        NAME "Red River Basin"
        SYMBOL 'plainline'
        COLOR 255 0 0
        SIZE 2
      END
END
END #map file
-----Original Message-----
From: Debbie Pagurek [mailto:pagurekd at agr.gc.ca]
Sent: Tuesday, June 04, 2002 8:21 AM
To: mapserver-users at lists.gis.umn.edu; Brian Fischer
Subject: Re: [mapserver-users] WMS Client Support
Your WMS request is not formated correctly.  For instance, in the layer
from DMSolutions, you are missing REQUEST=getmap:
http://www2.dmsolutions.ca/cgi-bin/mswms_gmap?VERSION=1.1.0&REQUEST=getM
AP&LAYERS=bathymetry&FORMAT=image/gif
Make sure that the URL for your WMS layers are working in a browser
before adding them to your mapfile.  Also, I don't know what your other
layers are, but make sure that the order of your layers in your mapfile
is correct so that you aren't covering the WMS layer with opaque layers.
D. Pagurek
>>> "Brian Fischer" <bfischer at mpls.houstoneng.com> 06/03/02 02:42PM >>>
Hi MapServer WMS users,
I am new to the WMS feature of MapServer.  I am trying to add a WMS
layer to my current mapserver application and I am not having any
success.  I have read through the WMS Client HowTo and an old posted
message
(http://mapserver.gis.umn.edu/cgi-bin/wilma_hiliter/mapserver-users/0204
/msg00314.html) and neither seem to work for me.  I am using
MapServer3.5 with WMS_Client Support.
When I insert the WMS layer into the map file all I see in the web
browser are my non-wms layers.  None of the WMS layers seem to show up.
I have tried two different WMS layers; one from the Geography Network as
used in the old posted message and one by DMSoultions in the WMS HowTo.
My map file is attached below.  Can anyone see any reason why the WMS
layers wouldn't be showing up in the web browser?
Thanks,
Brian
# RRBDINviewer.map
MAP
   NAME "RRBDINViewer"
   SIZE  500 400
   UNITS METERS
   Projection
     "init=epsg:4326"
   END
   WEB
      MAXSCALE 7000000
   END
   QUERYMAP
      STATUS ON
      STYLE HILITE
      COLOR 255 255 0
   END
   LEGEND
      STATUS ON
      LABEL
         TYPE TRUETYPE
         ANTIALIAS TRUE
         FONT arial
         COLOR 0 0 0
         SIZE 9
      END
   END
   SCALEBAR
      STATUS ON
      INTERVALS 4
      SIZE 150 6
      COLOR 0 0 0
      STYLE 1
      UNITS MILES
      LABEL
         ANTIALIAS TRUE
         COLOR 0 0 0
         SIZE tiny
      END
   END #scalebar
   REFERENCE
      STATUS ON
      SIZE 150 153
      COLOR -1 -1 -1
   END #reference
LAYER
  NAME "esri"
  METADATA
            "wms_title" "ESRI - WORLD"
            "wms_srs" "epsg:4326"
            "wms_connectiontimeout" "1000"
  END
  TYPE RASTER
  STATUS ON
  CONNECTION
"http://www.geographynetwork.com/servlet/com.esri.wms.Esrimap?ServiceNam
e=ESRI_World&VERSION=1.0.0&REQUEST=map&Layers=Rivers&Format=gif"
  CONNECTIONTYPE WMS
  PROJECTION
            "init=epsg:4326"
  END
End #layer esri
LAYER
  NAME bathmetry
  METADATA
            "wms_srs" "EPSG:42403 EPSG:4269 EPSG:4326"
  END
  TYPE RASTER
  STATUS ON
  CONNECTION
"http://www2.dmsolutions.ca/cgi-bin/mswms_gmap?VERSION=1.1.0&LAYERS=bath
ymetry&FORMAT=image/gif"
  CONNECTIONTYPE WMS
  PROJECTION
            "init=epsg:4326"
  END
LAYER
      NAME pol_bndry
      DATA "pol_bnd"
      STATUS DEFAULT
      TYPE LINE
      PROJECTION
            "init=epsg:4326"
      END
      LABELITEM "NAME"
      CLASS
         COLOR 50 50 50
         SYMBOL 2
         LABEL
          FORCE TRUE
          SIZE 12
          COLOR 50 50 50
          BUFFER 4
          TYPE TRUETYPE
          FONT arial-bold
          ANTIALIAS TRUE
        END
      END
   END
LAYER
      NAME watershed
      STATUS DEFAULT
      TYPE LINE
      PROJECTION
            "init=epsg:4326"
      END
      CLASS
        SYMBOL 'plainline'
        COLOR 255 0 0
        SIZE 2
      END
END
END #map file
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20020604/ab53840d/attachment.html
