[mapserver-users] WMS Client Support
Daniel Morissette
morissette at dmsolutions.ca
Wed Jun 5 17:32:31 EDT 2002
Brian Fischer wrote:
> I want to say thanks to Debbie for her help. Wow this one was so
> simple, but took a while to figure out. It turns out that if you have
> the STATUS set to ON the WMS layer will not display. If you change the
> STATUS to DEFAULT the WMS layer displays. Is a WMS layer suppose to
> behave like this? It took me a while to figure this one out, so I hope
> it saves someone else some time.
WMS layers behave exactly the same way as other layers with respect to
the STATUS setting. Note that with the mapserv CGI, layers that have
STATUS ON are displayed *only if* they are explicitly requested via a
layer=name parameter in the URL. Did you make sure that your HTML
interface template was passing this parameter to the mapserv CGI?
Daniel Morissette morissette at dmsolutions.ca
DM Solutions Group http://www.dmsolutions.ca/
Don't put for tomorrow what you can do today, because if
you enjoy it today you can do it again tomorrow.
