[mapserver-users] Connecting Oracle Spatial
Yu-Hsin Chen
ychen at yorktel.com
Fri Jun 7 23:10:26 EDT 2002
Back in late February when I first try to get mapserver to work with Oracle (8.1.7i) I had connect problem. I don't recall if the error message is exactly the same as yours. I ended up add the following lines in my Apache web server configuration file for the Oracle connect to be successful:
<IfModule mod_env.c>
SetEnv ORACLE_SID gisdb
SetEnv ORACLE_HOME /opt/oracle/product/9.0.1
</IfModule>
The file I modifid was commonhttpd.conf it may be different for you. I'm not sure if this solves your problem or not but if you're running out of solutions this won't hurt.
Yu-Hsin
-----Original Message-----
From: lballard at YesVirginia.org [mailto:lballard at YesVirginia.org]
Sent: Fri 6/7/2002 12:43 PM
To: mapserver-users at lists.gis.umn.edu
Cc:
Subject: [mapserver-users] Connecting Oracle Spatial
ERROR:
msOCIConnect() in msOracleSpatialLayerOpen(): OracleSpatial error.
Redhat 7.2
Oracle Client 9.0.1
Mapserver nightly build 6/6
Config command:
./configure --with-oraclespatial=/opt/oracle/product/9.0.1/
--with-sde=/usr/local/apache/htdocs/mapserver/tmp/sdeexe81/
--with-sde-version=81
--with-gd=static,/usr/local/apache/htdocs/mapserver/tmp/gd-1.8.4/
Map File snippet:
LAYER
NAME states
TYPE polygon
STATUS default
MAXSCALE 10000000
CONNECTIONTYPE oraclespatial
CONNECTION 'u/p at gisdb'
DATA "SHAPE FROM LD_QT_NAMSTATES_SDO"
CLASS
NAME 'states'
COLOR 220 224 230
OUTLINECOLOR 0 0 0
END
END
tnsping:
[oracle at gisintranet tmp]$ tnsping gisdb
TNS Ping Utility for Linux: Version 9.0.1.0.0 - Production on 07-JUN-2002
12:38:51
Copyright (c) 1997 Oracle Corporation. All rights reserved.
Used parameter files:
/opt/oracle/product/9.0.1/network/admin/sqlnet.ora
Used ONAMES adapter to resolve the alias
Attempting to contact
(DESCRIPTION=(SOURCE_ROUTE=OFF)(ADDRESS_LIST=(ADDRESS=(PROTOCOL=TCP)(HOST=qt
vadb01.questerra.com)(PORT=1521)))(CONNECT_DATA=(SID=gisdb)(SRVR=DEDICATED))
OK (10 msec)
I can connect successfully through SQPLUS.
I added the Oracle Library path to the httpd.conf file:
setenv LD_LIBRARY_PATH /opt/oracle/product/9.0.1/lib
Thanks,
Lowell Ballard
