[mapserver-users] Custom Annotation
Stephen Woodbridge
woodbri at swoodbridge.com
Sat Jun 8 10:57:52 EDT 2002
I would think this could be done with mapscript. I'm just thinking
outloud here, but if you created a layer that had the definition of how
you wanted your labels rendered, then in mapscript if you are in that
layer's min-max range, you could query the polygon shapefile given the
mapextents and get a list of the polygons. You would need to get the
point to place the label, then fetch the NAME attribute. In Perl:
my $newname = join(" ", split(//, $oldname));
will convert "PENNSYLVANIA" to "P E N N S Y L V A N I A"
then just draw the label using the layer's definition. I know this
sounds like a lot of work, but I think it is pretty straight forward
unless I am missing something.
-Steve
imap at chesapeake.net wrote:
> I've a question about some custom annotation.. And I am hoping someone
> might have some ideas...
> At certain mapscales, I'd like to display a state/province name
> annotated with spacing between the letters, like you might seen
> on printed cartographic maps... ie. A L B E R T A
> or: P E N N S Y L V A N I A
> This isn't something I want to hardcode into the data, but it
> would be a nice feature to have a keyword (charspacing) or some
> such to accomplish the task. Probably a knarly task, but I
> will throw the idea out there anyway...
> Regards,
> Chris
