[mapserver-users] demo on Mac X
Marcel v d Bilt
M.v.d.Bilt at chello.nl
Sun Jun 9 17:55:24 EDT 2002
Hi all i am finally busy with the map sever but
have some troubles to set the demo up
I spend now several hours to find out what is going wrong
changing directories etc
OS X keeps the web documents in
/Library/WebServer/Documents
and cgi in
/Library/WebServer/CGI-Executables with an script alias in httpd.conf
cgi-bin
this is the terminal output ./mapserv.cgi -v
localhost:/Library/WebServer/CGI-Executables] orangebo% ./mapserv.cgi -v
MapServer version 3.5 OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP SUPPORTS=PROJ
SUPPORTS=TTF SUPPORTS=WMS_SERVER INPUT=EPPL7 INPUT=JPEG INPUT=GDAL
INPUT=SHAPEFILE
[localhost:/Library/WebServer/CGI-Executables] orangebo%
i get this error from the demo_init.html
msLoadMap(): Unknown identifier. (SHADESET):(6)
This is in the demo_init.html
<html>
<head><title>MapServer Demo Interface</title></head>
<body bgcolor="#FFFFFF">
<center><h2>MapServer Demo Interface</h2></center>
<p><hr><p>
Click on the initialize button to fire up the demo with 3 layers turned
on will be accessible for browsing. The
data are of Itasca County, MN and were derived, for the most part, from
USGS 1:24,000 quadrangles. Some things to note are:
<form method=GET action="/cgi-bin/mapserv.cgi">
<input type="hidden" name="map"
value="/Library/WebServer/Documents/ms_demo/demo.map">
<input type="hidden" name="layer" value="lakes">
<input type="hidden" name="layer" value="streams">
<input type="hidden" name="zoomsize" value=2>
<center><input type="submit" value="Initialize"></center>
</form>
<p><hr><p>
This is in the demo.map file
# Start of web interface definition
WEB
HEADER demo_header.html
TEMPLATE demo.html
FOOTER demo_footer.html
MINSCALE 1000
MAXSCALE 1550000
IMAGEPATH "/Library/WebServer/Documents/ms_demo/tmp/"
IMAGEURL "/ms_demo/tmp/"
# LOG "/Library/WebServer/Documents/ms_demo/demo.log"
END
QUERYMAP
i specialy created this tmp dir the server needs it probably to store
the produced image?
and this is the demo.html
<html>
<body bgcolor=#FFFFFF>
<center><h1>MapServer Demo Interface</h1></center>
<hr>
<center>
<table border=0 cellspacing=0 cellpadding=4 bgcolor="#000000">
<tr>
<td valign="top" align=center>
<table cellpadding="0" cellspacing="0" border="0">
<tr><td colspan="2"><INPUT NAME="img" TYPE="image" SRC="[img]"
width=600 height=600 border=0></td></tr>
<tr>
<td> <font size=-1 face="arial,helvetica"
color="#FFFFFF"><b>Powered by MapServer</b></font></td>
<td align="right"><img src="[scalebar]"></td>
</tr>
</table>
</td>
<td valign="top" bgcolor=#ffffff>
<table cellpadding="5" cellspacing="0" border="0" bgcolor="#ffffff">
<tr><td>
<center><input type="submit" value="Refresh/Query"></center>
<p>
<input type="radio" name="mode" value="browse" checked> <b>Browse
map</b><br>
<input type="radio" name="mode" value="query"> <b>Query
feature</b><br>
<input type="radio" name="mode" value="nquery"> <b>Query multiple
features</b>
<hr>
<p>
<b>Select Layers to Display: </b><br>
<select multiple name="layer" size=3>
<option value="cities" [cities_select]> Cities
<option value="lakes" [lakes_select]> Lakes & Rivers
<option value="streams" [streams_select]> Streams
<option value="roads" [roads_select]> Roads
<option value="townships" [townships_select]> Townships
</select>
<p>
Zoom In <input type=radio name=zoomdir value=1 [zoomdir_1_check]>
Pan <input type=radio name=zoomdir value=0 [zoomdir_0_check]>
Zoom Out <input type=radio name=zoomdir value=-1
[zoomdir_-1_check]>
<p>
Zoom Size <input type=text name=zoomsize size=4 value=[zoomsize]>
<p>
<font size=+1><b>Legend</b></font><br><hr>
<img src="[legend]"><hr>
<p>
<center><INPUT NAME="ref" TYPE="image" SRC="[ref]"
border="0"></center>
</td></tr></table>
</td></tr>
</table>
</center>
<input type="hidden" name="imgxy" value="299.5 299.5">
<input type="hidden" name="imgext" value="[mapext]">
value="[/Library/Webserver/Documents/ms_demo/demo.map]">
<input type="hidden" name="savequery" value="true">
<input type="hidden" name="mapext" value="shapes">
</form>
<p><hr><p>
</body></html>
and it produces this error
msLoadMap(): Unable to access file. Illegal mapfile name.
I hope some one can point me out on this i got a compiled version 3.5
from
Puneet Kishor <pkishor at geoanalytics.com>
Name: not available
Type: text/enriched
Desc: not available
Url : http://lists.osgeo.org/pipermail/mapserver-users/attachments/20020609/1f803ff8/attachment.bin
