[mapserver-users] Problem: Transparent polygon with outline
Stephen Woodbridge
woodbri at swoodbridge.com
Sun Jun 9 18:13:51 EDT 2002
Try this and then make variations to suit your needs:
CLASS NAME "transparent"
SYMBOL "circle"
SIZE 5
COLOR -1 -1 -1
OUTLINECOLOR 0 0 0
END
-Steve
Markus Spring wrote:
> Hi list,
> I am trying to render the following layer definition:
> LAYER NAME l2
> DATA "/data/muc/shapes_ms/bezirk_96"
> CLASSITEM "Area"
> SYMBOL 0
> SIZE 5
> COLOR -1 -1 -1
> OVERLAYSYMBOL line0
> OVERLAYOUTLINECOLOR 0 0 0
> OVERLAYSIZE 3.00000000000000
> END # class
> TYPE polygon
> END # layer l2
> It is a polygon shape, which should be rendered outline only. I know I
> could change the type, but assuming a multi-class layer with
> transparent and non transparent classes, this wouldn't help.
> Crazy thing is, the legend image shows the outline (with 3.6), so I am
> really puzzled
> Anyone knowing an explanation or workaround - or should I file it as
> a bug?
> Markus
