[mapserver-users] compile error
Jean-Francois.Doyon at ccrs.nrcan.gc.ca Jean-Francois.Doyon at ccrs.nrcan.gc.ca
Thu Jun 13 17:28:24 EDT 2002
The build process isn't finding your GD header files (gd.h) ... make sure
you have them installed ... if you know WHERE they are, you can try passing
the path to the library with --with-gd=/usr/local/ for instance ... you
can't be too far off if configure found your GD Lib ...
Am I reading right ? You're using MS 3.3 ?? I'd strongly suggest you upgrade
to 3.6 !!!
J.F.
-----Original Message-----
From: bertha amalia serrato de la cruz [mailto:bertha_bonita at yahoo.com]
Sent: Thursday, June 13, 2002 4:27 PM
To: mapserver-users at lists.gis.umn.edu
Subject: [mapserver-users] compile error
hi
i tryed install MS as follow:
./configure --with-gd --with-ttf
but i dont know how can i fix the next errors...
[129]:{abaco}bserrato-> make
cd gdft; make; cd ..
gcc -c -O2  -Wall -DUSE_GD_1_6  -DUSE_TTF
-I/web/docswww/geologia/docs/bertha/ms
33/mapserver/gdft -I/usr/local/include/freetype
gdkanji.c
gdcache.c
gdttf.c
gdttf.c:11: gd.h: No such file or directory
*** Error code 1
make: Fatal error: Command failed for target `gdttf.o'
Current working directory
/web/docswww/geologia/docs/bertha/ms33/mapserver/gdft
*** Error code 1
make: Fatal error: Command failed for target `gdft'
somedoby can help me? please.
    LCC.Bertha A. Serrato
    bserrato at cicese.mx
    Laboratorio de Percepción Remota y S.I.G.
    CICESE,División de Ciencias de la Tierra.
    Ensenada, B.C.
_______________________________________________________________
Copa del Mundo de la FIFA 2002
El único lugar de Internet con vídeos de los 64 partidos.
¡Apúntante ya! en http://fifaworldcup.yahoo.com/fc/es/
