[mapserver-users] Join labels and attribute query
Matthias Scholz matthias.scholz at vgem-klostermansfeld.de
Mon Jun 17 09:15:49 EDT 2002
Hello,
how can i join two or more labels and display it at once? I use shape-files as
data. In the dbf-file i have the following attributes: ID, RECHTSWERT, HOCHWERT,
DATUM, FOLIE, OBJART, ALIASFOLIE, ALIASART, ALK-NR, GEMARKUNG, FLUR, ZAEHLER,
NENNER
For this Layer i need an annotation in the form: "ZAEHLER/NENNER" This is the
notation in german "Flurkarten". In the dbf-file i cannot join this two columns,
because the converter for the shape-files writes the files and the slash between
ZAEHLER and NENNER is important. I have try it, but i can only view one
annotation :-(
My second problem is how i can make a query with with attributes? In a html form
i have the fields GEMARKUNG, FLUR, ZAEHLER, NENNER. Together are this four
attribues uniqe in the dbf-file. Is it possible to make a query with more than
one attribute?
Thanks for help!!!
Matthias Scholz
:  Verwaltungsgemeinschaft Klostermansfeld       :
:  Kirchstr. 1                                   :
:  06308 Klostermansfeld                         :
:  Telefon: (+49) 034772/800                     :
:  Telefax: (+49) 034772/80200                   :
:  eMail: info at vgem-klostermansfeld.de           :
:  WWW: http://www.vgem-klostermansfeld.de       :
Diese eMail wurde mit IMP 3.0 gesendet (http://www.horde.org)
