[mapserver-users] MapInfo "Seamless" layer performance issues
Daniel Morissette
morissette at dmsolutions.ca
Sun Jun 23 16:30:20 EDT 2002
Hi Dan,
The performance issue that you noticed is not normal, so I have filed a
bug about this http://mapserver.gis.umn.edu/bugs/show_bug.cgi?id=164
Can you please add to the bug report your configuration information:
MapServer/MapScript version, OS, GDAL/OGR version to help us reproduce
it?
Thanks,
Daniel
"Martin, Daniel" wrote:
> I'm trying to use MapInfo Seamless layers in MapServer. They do work, which
> is great. But they are slow relative to the individual layers. To
> elaborate, I have one Postal Code layer per state. To treat them as a
> single layer for a National mapping application, I have created a "Seamless"
> layer to pull them all together.
> Now, I expect that to be slow. Even pulling it into MapInfo is slow. It's
> a huge amount of data. However, if I zoom in to a scale of a few miles, I
> should only be loading one layer because I can only see one state. But even
> this is very slow. If I load the same map using the actual physical layer
> rather than the seamless, it's pretty fast, even though it's displaying the
> same data. Even if I merge the entire national Postal Code dataset into one
> gigantic layer, it performs fairly fast, so the issue cannot be in the
> volume of data. Specifically this last example doesn't seem to make sense.
> And the performance difference is minutes as opposed to seconds, Seamless
> vs. normal.
> Is there something I can do to improve performance of a Seamless layer? Or
> is it just a reality, and I should look to combining my data.
> Thanks,
> Dan Martin
