[mapserver-users] First time users: black output from mapserver
3.6.0 using itasca demo dataset
Cedric BERNIER
cedric.bernier at thales-is.com
Wed Jun 26 08:32:56 EDT 2002
I've exactly the same problem on redHat 7.2
Thank you for your help.
"Harahap, Zuki" a écrit :
> Hi everyone,
> I just started using mapserver, so please accept my apology if the questions is too simple and basic.
> I have installed mapserver 3.6.0 and itasca demo dataset. Installation seems OK. But when I looked the result via browser (mozilla, konqueror, IE) all I got in MapServer Demo Interface page is a black map with some feature on its right side (refresh/query, browse map, query feature, and so on). I could click on the map and the mapserv perform an action. However, the result is still same, nothing there, only black.
> I compiled mapserv in RedHat 7.1, using its library for jpeg, freetype, png, and gd (version 1.8.3.7). I just straightly compile (./configure and then make) and then put it on Apache web server as I just would like to see the result. When I configure it, it says:
> using GD (-DUSE_GD_PNG -DUSE_GD_JPEG -DUSE_DG_WBMP -DUSE_GD_TTF) from system libs
> I convert gif files of demo dataset (under graphics and symbol) using convert utility from ImageMagic. Then I have changed name of gif files within demo.map file to point to converted png files. I looked at files using gimp and they seems OK.
> I looked archived of this mailing list and someone said that I need to set and compile the mapserver executable to use GIF OR PNG at compile time. But I couldn't find anything on ./configure --help that helps me to set this up.
> Any help would be appreciated.
> Thanks a lot,
> Zuki
Type: text/x-vcard
Desc: Carte pour Cedric BERNIER
Url : http://lists.osgeo.org/pipermail/mapserver-users/attachments/20020626/2b2c6263/cedric.bernier.vcf
