[mapserver-users] TIFFs and ECWs rasters get a monochrome output - why?
    Alexander Gleyzer
    agleyzer at bezeqint.net
    Tue Sep 24 13:17:03 PDT 2002
Thanks, Anders!
That actually worked, the ECWs are now displayed in color.
BTW, regarding the TIFFs, I tried some program which converts them to 8 bit - and now they
also show up in color. So that all the problems are solved.
Thank you all, also Andrew Hallan.
Alexander Gleyzer.
  ----- Original Message -----
  To: Alexander Gleyzer ; mapserver-users at lists.gis.umn.edu
  Sent: Tuesday, September 24, 2002 8:21 AM
  Subject: SV: [mapserver-users] TIFFs and ECWs rasters get a monochrome output - why?
  I've seen this behaviour too..... I've found out that it depends on whether or not I have a Class object in my layers (I have one tileindex layer). If i remove the class object my ecw's show up in color, and if I add a class object they show up in black/white... (I actually use this as a feature, since most of my ecw images look ugly in color)....
  Hope this helps.
  / Anders
    -----Oprindelig meddelelse-----
    Fra: Alexander Gleyzer [mailto:agleyzer at bezeqint.net]
    Sendt: 23. september 2002 23:28
    Til: mapserver-users at lists.gis.umn.edu
    Emne: [mapserver-users] TIFFs and ECWs rasters get a monochrome output - why?
    Hi!
    I'm using MapServer raster layers to present large background images.
    When I got to large TIFFs (>200 MB) the server displayed an error message (unsupported image format or smth.).
    I tried to download the GDAL support version (precompiled Win-32 binaries),
    which also supports ECW (I have those TIFFs compressed to ECWs).
    But when I fired it up - all the output turned out black-and-white, never mind the output format (GIF, JPG, PNG)!
    Why is that happening? Is there a way to normally present large TIFFs or their ECW equivalents?
    Thanks!
    Alexander Gleyzer.
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20020924/285f0d13/attachment.htm>
More information about the MapServer-users
