[Mapserver-users] once again compiling with TTF-Support
Daniel Morissette morissette at dmsolutions.ca
Mon Apr 7 19:43:41 EDT 2003
I see 2 possibilities:
1- MapServer got linked with an old libmap.a ... check and if you find
an old /usr/local/lib/libmap.a on your system then delete it and
recompile MapServer.  (And avoid using 'make install' with MapServer in
the future, 'make install' has some issues and will be gone in future
releases)
2- This could be a GD2 vs MapServer 3.6 thing: I dont't think MapServer
3.6.x has been used/tested much with GD2.x... so it's safer to use GD
1.8.x and freetype 1.3 with MapServer 3.6.
Daniel
Bjoern Platzen wrote:
> Hi all,
> I'm fighting with the TTF-Support for MapServer 3.6.4.
> I'm using Freetype 2.1.4rc2, a patched gd 2.0.7 on a SuSE Linux 8.0 Box.
> I compiled the GD and it said:
> ** Configuration summary for gd 2.0.7:
>    Support for PNG library:          yes
>    Support for JPEG library:         yes
>    Support for Freetype 2.x library: yes
>    Support for Xpm library:          yes
> Then I compiled the MapServer and it said
>  using GD ( -DUSE_GD_GIF -DUSE_GD_PNG -DUSE_GD_JPEG -DUSE_GD_WBMP
> -DUSE_GD_FT -DGD_HAS_GDIMAGEGIFPTR) from
> /home/platzen/download/gd-2.0.7gif/.
> Now it seemed to me as if everything should be right, but it isn't! The
> CGI-Output still tells me:
> loadlabel(): Unknown identifier. Keyword FONT is not valid without
> TrueType font support.
> Is there anything else, that I forgot??
> Any help would be really great...
> Thanks in advance,
> Bjoern
> small office solutions
> info at sosnetz.de  -  http://www.sosnetz.de
