[Mapserver-users] once again compiling with TTF-Support
Björn Platzen
bplatzen at sosnetz.de
Tue Apr 8 02:39:16 EDT 2003
Hello Daniel,
> 1- MapServer got linked with an old libmap.a ... check and if you
> find an old /usr/local/lib/libmap.a on your system then delete it and
> recompile MapServer.
libmap.a was from yesterday, deleting and recompiling had no effect.
> 2- This could be a GD2 vs MapServer 3.6 thing: I dont't think
> MapServer 3.6.x has been used/tested much with GD2.x... so it's safer
> to use GD 1.8.x and freetype 1.3 with MapServer 3.6.
I tried that with a patched Version of GD 1.8.4 and Freetype 1.3.1 but I
could not compile the GD with freetype-support. It always said:
checking for freetype.h... (cached) no
configure: warning: libgd will be built without support for TrueType
fonts - no freetype.h.
checking for TT_Init_FreeType in -lttf... (cached) yes
I checked, if freetype.h is there and it is (in /usr/include/freetype
and in /usr/local/include/freetype).
The first GD that found freetype.h was this 2.0.7-Version.
Thanks for your help, I'll try to get it started somehow with GD 1.8.4.
Bye,
Bjoern
> Daniel
> Bjoern Platzen wrote:
> > Hi all,
> > I'm fighting with the TTF-Support for MapServer 3.6.4.
> > I'm using Freetype 2.1.4rc2, a patched gd 2.0.7 on a SuSE Linux 8.0
> > Box.
> > I compiled the GD and it said:
> > ** Configuration summary for gd 2.0.7:
> > Support for PNG library: yes
> > Support for JPEG library: yes
> > Support for Freetype 2.x library: yes
> > Support for Xpm library: yes
> > Then I compiled the MapServer and it said
> > using GD ( -DUSE_GD_GIF -DUSE_GD_PNG -DUSE_GD_JPEG -DUSE_GD_WBMP
> > -DUSE_GD_FT -DGD_HAS_GDIMAGEGIFPTR) from
> > /home/platzen/download/gd-2.0.7gif/.
> > Now it seemed to me as if everything should be right, but it isn't!
> > The CGI-Output still tells me:
> > loadlabel(): Unknown identifier. Keyword FONT is not valid without
> > TrueType font support.
> > Is there anything else, that I forgot??
> > Any help would be really great...
> > Thanks in advance,
> > Bjoern
> > small office solutions
> > info at sosnetz.de - http://www.sosnetz.de
