[Mapserver-users] PHP problem
Eduardo Spremolla
edspremolla at Antel.com.uy
Wed Apr 9 11:57:47 EDT 2003
I have that problem too on RH 7.2
mapscript install on /usr/local/lib/php/extensions/ so I link
php_mapscript.so into no-debug-non-zts-20020429.
LALO
El mié, 09 de 04 de 2003 a las 12:29, Jehng-Jung Kao escribió:
> On Wed, 9 Apr 2003, Tyler Mitchell wrote:
> > Is there more to your error message that you can share with us?
> Sure, here it is:
> Warning: dl() [function.dl]: Unable to load dynamic library '/usr/local/lib/php/extensions/no-debug-non-zts-20020429/php_mapscript.so' - libgdal.1.1.so: cannot open shared object file: No such file or directory in /users/stin/public_html/mapscript/info.php on line 6
> Can not load php_mapscript.so
> But info.php executed ok locally on my linux.
> Does apache or php limit any on-line dynamic library loading? (Not quite sure.)
> Error message is produced by the following php script:
> http://ns2.stin.org.tw/~stin/mapscript/info.php
> Php info can be found with
> http://ns2.stin.org.tw/~stin/mapscript/phpinfo.php
> -- jjkao
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
