[Mapserver-users] PHP problem
Matt Doggett
mdoggett at coas.oregonstate.edu
Wed Apr 9 17:20:49 EDT 2003
Aha! Just wrestled (and won) with this very same problem this morning.
Find out where PHP is looking for the php.ini file. In my case, I
compiled PHP with --with-config-file-path=/usr/local/php but I forgot to
put the php.ini in that location. This is important because within
php.ini is a setting called extension_dir which tells php where to look
for extensions. Make sure this is set to wherever you put your
php_mapscript.so file (in my case
extension_dir=/usr/local/apache2/modules)
This should solve your problem.
Matt
(RedHat8.0, Apache2.0, Mapserver 3.6.4, Php4.2.3)
Matt Doggett
Spatial Climate Analysis Service
Oregon State University
316 Strand Ag Hall
Corvallis, OR 97331
(541)737-9153
> -----Original Message-----
> From: mapserver-users-admin at lists.gis.umn.edu [mailto:mapserver-users-
> admin at lists.gis.umn.edu] On Behalf Of Jehng-Jung Kao
> Sent: Wednesday, April 09, 2003 8:29 AM
> To: Tyler Mitchell
> Cc: mapserver-users at lists.gis.umn.edu
> Subject: Re: [Mapserver-users] PHP problem
> On Wed, 9 Apr 2003, Tyler Mitchell wrote:
> > Is there more to your error message that you can share with us?
> Sure, here it is:
> Warning: dl() [function.dl]: Unable to load dynamic library
'/usr/local/lib/php/extensions/no-debug-non-zts-20020429/php_mapscript.s
o'
> - libgdal.1.1.so: cannot open shared object file: No such file or
> directory in /users/stin/public_html/mapscript/info.php on line 6
> Can not load php_mapscript.so
> But info.php executed ok locally on my linux.
> Does apache or php limit any on-line dynamic library loading? (Not
quite
> sure.)
> Error message is produced by the following php script:
> http://ns2.stin.org.tw/~stin/mapscript/info.php
> Php info can be found with
> http://ns2.stin.org.tw/~stin/mapscript/phpinfo.php
> -- jjkao
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
