[Mapserver-users] Perl under windows
Adam Zornes zornes at athenic.com
Thu Apr 10 14:04:24 EDT 2003
This is a multi-part message in MIME format.
------_=_NextPart_001_01C2FF8B.9E5D6128
Content-Type: text/plain;
	charset="us-ascii"
Content-Transfer-Encoding: quoted-printable
Dear All,
=20
            I am trying to run perl mapscript in a windows environment.
I have the latest version of mapserver, and a perl environment and both
are working just fine.=20
            When I try to run a perl script with mapscript, I get an
error that I am missing mapscript.pm.  Okay, fine, but how do I get said
file?  Is this all that is required
to correct the problem, or is this only the beginning?
=20
Cheers,
Adam Zornes
Content-Type: text/html;
	charset="us-ascii"
<html xmlns:o=3D"urn:schemas-microsoft-com:office:office" =
xmlns:w=3D"urn:schemas-microsoft-com:office:word" =
xmlns=3D"http://www.w3.org/TR/REC-html40">
<head>
<META HTTP-EQUIV=3D"Content-Type" CONTENT=3D"text/html; =
charset=3Dus-ascii">
<meta name=3DProgId content=3DWord.Document>
<meta name=3DGenerator content=3D"Microsoft Word 10">
<meta name=3DOriginator content=3D"Microsoft Word 10">
<link rel=3DFile-List href=3D"cid:filelist.xml at 01C2FF6A.156CBFE0">
<!--[if gte mso 9]><xml>
 <o:OfficeDocumentSettings>
  <o:DoNotRelyOnCSS/>
 </o:OfficeDocumentSettings>
</xml><![endif]--><!--[if gte mso 9]><xml>
 <w:WordDocument>
  <w:SpellingState>Clean</w:SpellingState>
  <w:GrammarState>Clean</w:GrammarState>
  <w:DocumentKind>DocumentEmail</w:DocumentKind>
  <w:EnvelopeVis/>
  <w:Compatibility>
   <w:BreakWrappedTables/>
   <w:SnapToGridInCell/>
   <w:WrapTextWithPunct/>
   <w:UseAsianBreakRules/>
  </w:Compatibility>
  <w:BrowserLevel>MicrosoftInternetExplorer4</w:BrowserLevel>
 </w:WordDocument>
</xml><![endif]-->
<style>
 /* Style Definitions */
 p.MsoNormal, li.MsoNormal, div.MsoNormal
	{mso-style-parent:"";
	margin:0in;
	margin-bottom:.0001pt;
	mso-pagination:widow-orphan;
	font-size:12.0pt;
	font-family:"Times New Roman";
	mso-fareast-font-family:"Times New Roman";}
a:link, span.MsoHyperlink
	{color:blue;
	text-decoration:underline;
	text-underline:single;}
a:visited, span.MsoHyperlinkFollowed
	{color:purple;
span.EmailStyle17
	{mso-style-type:personal-compose;
	mso-style-noshow:yes;
	mso-ansi-font-size:10.0pt;
	mso-bidi-font-size:10.0pt;
	font-family:Arial;
	mso-ascii-font-family:Arial;
	mso-hansi-font-family:Arial;
	mso-bidi-font-family:Arial;
	color:windowtext;}
span.SpellE
	{mso-style-name:"";
	mso-spl-e:yes;}
span.GramE
	{mso-style-name:"";
	mso-gram-e:yes;}
@page Section1
	{size:8.5in 11.0in;
	margin:1.0in 1.25in 1.0in 1.25in;
	mso-header-margin:.5in;
	mso-footer-margin:.5in;
	mso-paper-source:0;}
div.Section1
	{page:Section1;}
</style>
<!--[if gte mso 10]>
<style>
 /* Style Definitions */=20
 table.MsoNormalTable
	{mso-style-name:"Table Normal";
	mso-tstyle-rowband-size:0;
	mso-tstyle-colband-size:0;
	mso-padding-alt:0in 5.4pt 0in 5.4pt;
	mso-para-margin:0in;
	mso-para-margin-bottom:.0001pt;
	font-size:10.0pt;
</style>
<![endif]-->
</head>
<body lang=3DEN-US link=3Dblue vlink=3Dpurple =
style=3D'tab-interval:.5in'>
<div class=3DSection1>
<p class=3DMsoNormal><font size=3D2 face=3DArial><span =
style=3D'font-size:10.0pt;
font-family:Arial'>Dear All,<o:p></o:p></span></font></p>
font-family:Arial'><o:p>&nbsp;</o:p></span></font></p>
font-family:Arial'><span =
style=3D'mso-tab-count:1'>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp=
;&nbsp;&nbsp;&nbsp; </span>I am trying
to run <span class=3DSpellE>perl</span> <span =
class=3DSpellE>mapscript</span> in a
windows environment.<span style=3D'mso-spacerun:yes'>&nbsp; </span>I =
have the latest
version of <span class=3DSpellE>mapserver</span>, and a <span =
environment and both are working just fine. =
;&nbsp;&nbsp;&nbsp; </span>When I try
to run a <span class=3DSpellE>perl</span> script with <span =
class=3DSpellE>mapscript</span>,
I get an error that I am missing <span =
class=3DSpellE>mapscript.pm</span>.<span
style=3D'mso-spacerun:yes'>&nbsp; </span>Okay, fine, but how do I get =
said file?<span
style=3D'mso-spacerun:yes'>&nbsp; </span>Is this all that is =
required<o:p></o:p></span></font></p>
<p class=3DMsoNormal><span class=3DGramE><font size=3D2 =
face=3DArial><span
style=3D'font-size:10.0pt;font-family:Arial'>to</span></font></span><font=
 size=3D2
face=3DArial><span style=3D'font-size:10.0pt;font-family:Arial'> correct =
the
problem, or is this only the beginning?<o:p></o:p></span></font></p>
font-family:Arial'>Cheers,<o:p></o:p></span></font></p>
font-family:Arial'>Adam Zornes<o:p></o:p></span></font></p>
</div>
</body>
</html>
------_=_NextPart_001_01C2FF8B.9E5D6128--
