[Mapserver-users] Querypoint
Eric Bridger eric at gomoos.org
Mon Apr 14 04:34:09 EDT 2003
(I'm not sure of the PHP syntax, but in Perl mapscript .. )
When you add your points to the layer you must save the shape index.
$layerObj->{index} and associate it with the mySql key value you want to
use.  When you query the layer, it's this index which is returned.
You must also create a template for your layer:
$layerObj->{template} = "junk.html"  in order to make the layer
queryable.
There is a perl mapscript example at:
http://mapserver.gis.umn.edu/cgi-bin/wiki.pl?PerlMapScriptExamples35ex14
Eric
On Fri, 2003-04-11 at 21:38, jose.quintal at cfe.gob.mx wrote:
> I have generated dynamic points with PHP-Mapscript. Now as I can do to him,
> so that when doing to him click to a point brings data to me of a data base
> of Mysql.
> Thanks
> José Antonio Quintal Castillo
> Comision Federal de Electricidad
> Mexico
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
