[Mapserver-users] msOCIConnect() in msOracleSpatialLayerOpen(): OracleSpatial error.
nakts at latnet.lv
nakts at latnet.lv
Wed Apr 16 05:49:26 EDT 2003
Hello
on Windows XP with
Oracle Client 8.1.7.
MapServer version 3.6.1 ..INPUT=ORACLESPATIAL ..
MapServer is on my local PC, Oracle DB - on other linux server.
Mapserver works fine with .shp files.
I can connect through SQPLUS, bu not this way:
LAYER
NAME "ielaaas"
STATUS DEFAULT
CONNECTIONTYPE oraclespatial
CONNECTION 'username.../pwd... at po1'
TYPE POLYGON
DATA "GEOM FROM SHP_CLIP96 USING SRID 82305"
CLASS
NAME "ielaaas"
COLOR 220 220 220
OUTLINECOLOR 0 0 0
END
END
I tried a lot of combinations in httpd.conf like:
LoadModule env_module modules/mod_env.so
<IfModule mod_env.c>
SetEnv ORACLE_SID po1
SetEnv ORACLE_HOME "C:\oracle\ora81"
SetEnv ORA_NLS33 "C:\oracle\ora81\ocommon\nls\ADMIN\DATA"
SetEnv LD_LIBRARY_PATH "C:\oracle\ora81\lib"
SetEnv TNS_ADMIN "C:\oracle\ora81\network\ADMIN"
</IfModule>
Where could be the problem, how to test what Mapserver is doing, how it tries to
connect to DB ?
Thanks,
Ima
