[Mapserver-users] Perl MapScript (3.7)
Babak Toloue Tehrani
babak.tehrani at geosysnet.de
Wed Apr 16 08:51:01 EDT 2003
Hello,
I am new to MapScript and try to get an output. I use Suse Linux 8.1
with Mapserver 3.7_dev (2003-03-14). Everithing is working fine:
/srv/www/cgi-bin/mapserv -v
MapServer version 3.7 (development) OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP
OUTPUT=SWF SUPPORTS=PROJ SUPPORTS=TTF SUPPORTS=WMS_SERVER
SUPPORTS=WMS_CLIENT SUPPORTS=WFS_SERVER SUPPORTS=WFS_CLIENT
SUPPORTS=GD2_RGB INPUT=TIFF INPUT=EPPL7 INPUT=JPEG INPUT=OGR INPUT=GDAL
INPUT=SHAPEFILE
Perl MapScript compiles also without an error.
# make install
Installing
/usr/lib/perl5/site_perl/5.8.0/i586-linux-thread-multi/auto/mapscript/mapscript.bs
Installing
/usr/lib/perl5/site_perl/5.8.0/i586-linux-thread-multi/auto/mapscript/mapscript.so
Files found in blib/arch: installing files in blib/lib into architecture
dependent library tree
Installing
/usr/lib/perl5/site_perl/5.8.0/i586-linux-thread-multi/mapscript.pm
Writing
/usr/lib/perl5/site_perl/5.8.0/i586-linux-thread-multi/auto/mapscript/.packlist
Appending installation info to
/usr/lib/perl5/5.8.0/i586-linux-thread-multi/perllocal.pod
I tried to write my first Perl Mapscript an run it with: perl demo.pl
and get following error:
Can't locate auto/mapscript/mapObj/selectOutpu.al in @INC (@INC
contains: /usr/lib/perl5/5.8.0/i586-linux-thread-multi
/usr/lib/perl5/site_perl/5.8.0 /usr/lib/perl5/site_perl .) at demo.pl
line 7
#!/usr/bin/perl -w
use strict;
use mapscript;
my $map = new mapscript::mapObj('brd_demo_geo.map') or die('Unable to
openmapfile.');
$map->selectOutputFormat("PNG");
$map->draw() or die('Unable to draw map');
my $img->saveImage();
# Start of map file
NAME BRD-DEMO
STATUS ON
SIZE 600 500
EXTENT 5.3 55.5 15.5 46.9
UNITS METERS
SHAPEPATH "data"
IMAGECOLOR 255 255 255
WEB
TEMPLATE brd_demo_geo.html
IMAGEPATH "set in brd_demo_geo_ini.html"
IMAGEURL "set in brd_demo_geo_ini.html"
END
OUTPUTFORMAT
NAME png
DRIVER "GD/PNG"
MIMETYPE "image/png"
IMAGEMODE PC256
EXTENSION "png"
END
QUERYMAP
STATUS OFF
SIZE -1 -1
COLOR 255 255 0
STYLE HILITE
END
LAYER
NAME brd
TYPE POLYGON
STATUS DEFAULT
DATA lnd01dd.shp
CLASS
NAME "brd"
SYMBOL 0
COLOR 195 195 195
OUTLINECOLOR 102 102 102
SIZE 1
MINSIZE 1
MAXSIZE 100
END
END
END
I am also not able to run the examples:
# perl shpinfo.pl -file=data/brd.shp
Usage: new_shapefileObj(filename,shapepath,type); at
/usr/lib/perl5/site_perl/5.8.0/i586-linux-thread-multi/mapscript.pm line
701.
Thanks a lot for helping:
Babak
