[Mapserver-users] esri ascii file support
Swaminathan, Gayathri
gayathri at ou.edu
Wed Apr 16 16:59:49 EDT 2003
This message is in MIME format. Since your mail reader does not understand
this format, some or all of this message may not be legible.
------_=_NextPart_001_01C3045B.1E80ABF0
Content-Type: text/plain
Gautam,
You will need to compile gdal-1.1.8 first before trying to compile it with
mapserver....You will need the path to gdal mentioned in your map file.
And another suggestion will be to do a 'make clean' whenever you try
compiling mapserver...You could comment out portions under "clean" option
that you dont want gone., (for
example regex.o etc.,)
This will ensure a "Rebuild all"
Gayathri
-----Original Message-----
From: Gautam Kumar [mailto:gautamleam at yahoo.com]
Sent: Wednesday, April 16, 2003 1:31 PM
To: mapserver-users at lists.gis.umn.edu
Subject: [Mapserver-users] esri ascii file support
I needed to get mapserver to read and display esri ascii files (.asc), and I
was wondering how this was done? I had installed gdal 1.1.8 as well because
i read that was needed for ascii files but when i tried to configure
mapserver to recognize that (./configure --with-gdal), and then ran make, it
spat back (make: Nothing to be done for `all'.) I'm not sure what that was
all about either. If anyone can help me with either of these two problems,
that would be very appreciated. Thanks.
_____
Do you Yahoo!?
The New <http://us.rd.yahoo.com/search/mailsig/*http://search.yahoo.com>
Yahoo! Search - Faster. Easier. Bingo.
Content-Type: text/html
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.0 Transitional//EN">
<HTML><HEAD>
<META HTTP-EQUIV="Content-Type" CONTENT="text/html; charset=US-ASCII">
<META content="MSHTML 6.00.2800.1141" name=GENERATOR></HEAD>
<BODY>
<DIV><SPAN class=371015522-16042003><FONT face=Arial color=#0000ff
size=2>Gautam,</FONT></SPAN></DIV>
<DIV><SPAN class=371015522-16042003><FONT face=Arial color=#0000ff size=2>You
file.</FONT></SPAN></DIV>
size=2></FONT></SPAN> </DIV>
<DIV><SPAN class=371015522-16042003><FONT face=Arial color=#0000ff size=2>And
another suggestion will be to do a 'make clean' whenever you try compiling
mapserver...You could comment out portions under "clean" option that you dont
want gone., (for </FONT></SPAN></DIV>
size=2>example regex.o etc.,)</FONT></SPAN></DIV>
<DIV><SPAN class=371015522-16042003><FONT face=Arial color=#0000ff size=2>This
will ensure a "Rebuild all"</FONT></SPAN></DIV>
size=2>Gayathri</FONT></SPAN></DIV>
<BLOCKQUOTE>
<DIV class=OutlookMessageHeader dir=ltr align=left><FONT face=Tahoma
size=2>-----Original Message-----<BR><B>From:</B> Gautam Kumar
[mailto:gautamleam at yahoo.com]<BR><B>Sent:</B> Wednesday, April 16, 2003 1:31
PM<BR><B>To:</B> mapserver-users at lists.gis.umn.edu<BR><B>Subject:</B>
[Mapserver-users] esri ascii file support<BR><BR></FONT></DIV>
<DIV>I needed to get mapserver to read and display esri ascii files (.asc),
and I was wondering how this was done? I had installed gdal 1.1.8 as well
because i read that was needed for ascii files but when i tried to configure
spat back (make: Nothing to be done for `all'.) I'm not sure what that was all
about either. If anyone can help me with either of these two problems, that
would be very appreciated. Thanks.</DIV>
<P><BR>
<HR SIZE=1>
Do you Yahoo!?<BR><A
href="http://us.rd.yahoo.com/search/mailsig/*http://search.yahoo.com">The New
Yahoo! Search</A> - Faster. Easier. Bingo.</BLOCKQUOTE></BODY></HTML>
------_=_NextPart_001_01C3045B.1E80ABF0--
