[Mapserver-users] esri ascii file support-Correction
Swaminathan, Gayathri gayathri at ou.edu
Wed Apr 16 17:25:36 EDT 2003
This message is in MIME format. Since your mail reader does not understand
this format, some or all of this message may not be legible.
------_=_NextPart_001_01C3045E.B8C5BEF0
Content-Type: text/plain
Sorry about the error in reply...the map file is actually "the mapserver
makefile"
-----Original Message-----
From: Swaminathan, Gayathri [mailto:gayathri at ou.edu]
Sent: Wednesday, April 16, 2003 2:00 PM
To: 'Gautam Kumar'; mapserver-users at lists.gis.umn.edu
Subject: RE: [Mapserver-users] esri ascii file support
Gautam,
You will need to compile gdal-1.1.8 first before trying to compile it with
mapserver....You will need the path to gdal mentioned in your map file.
(mapserver make file)
And another suggestion will be to do a 'make clean' whenever you try
compiling mapserver...You could comment out portions under "clean" option
that you dont want gone., (for
example regex.o etc.,)
This will ensure a "Rebuild all"
Gayathri
From: Gautam Kumar [mailto:gautamleam at yahoo.com]
Sent: Wednesday, April 16, 2003 1:31 PM
To: mapserver-users at lists.gis.umn.edu
Subject: [Mapserver-users] esri ascii file support
I needed to get mapserver to read and display esri ascii files (.asc), and I
was wondering how this was done? I had installed gdal 1.1.8 as well because
i read that was needed for ascii files but when i tried to configure
mapserver to recognize that (./configure --with-gdal), and then ran make, it
spat back (make: Nothing to be done for `all'.) I'm not sure what that was
all about either. If anyone can help me with either of these two problems,
that would be very appreciated. Thanks.
  _____
Do you Yahoo!?
The  <http://us.rd.yahoo.com/search/mailsig/*http://search.yahoo.com> New
Yahoo! Search - Faster. Easier. Bingo.
Content-Type: text/html
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.0 Transitional//EN">
<HTML><HEAD>
<META HTTP-EQUIV="Content-Type" CONTENT="text/html; charset=US-ASCII">
<META content="MSHTML 6.00.2800.1141" name=GENERATOR></HEAD>
<BODY>
<DIV><FONT face=Arial color=#0000ff size=2><SPAN class=624152423-16042003>Sorry
about the error in reply...<STRONG>the map file is actually "the mapserver
makefile"</STRONG></SPAN></FONT></DIV>
<BLOCKQUOTE dir=ltr style="MARGIN-RIGHT: 0px">
  <DIV class=OutlookMessageHeader dir=ltr align=left><FONT face=Tahoma
  size=2>-----Original Message-----<BR><B>From:</B> Swaminathan, Gayathri
  [mailto:gayathri at ou.edu]<BR><B>Sent:</B> Wednesday, April 16, 2003 2:00
  PM<BR><B>To:</B> 'Gautam Kumar';
  mapserver-users at lists.gis.umn.edu<BR><B>Subject:</B> RE: [Mapserver-users]
  esri ascii file support<BR><BR></FONT></DIV>
  <DIV><SPAN class=371015522-16042003><FONT face=Arial color=#0000ff
  size=2>Gautam,</FONT></SPAN></DIV>
  <DIV><SPAN class=371015522-16042003><FONT color=#0000ff><FONT face=Arial><FONT
  size=2>You will need to compile gdal-1.1.8 first before trying to compile it
  with mapserver....You will need the path to gdal mentioned in your
  <STRONG><FONT color=#ff0000>map file</FONT>.</STRONG><SPAN
  class=624152423-16042003><STRONG>&nbsp;(<FONT color=#008000>mapserver make
  file</FONT><FONT
  color=#0000ff>)</FONT></STRONG>&nbsp;</SPAN></FONT></FONT></FONT></SPAN></DIV>
  size=2></FONT></SPAN>&nbsp;</DIV>
  <DIV><SPAN class=371015522-16042003><FONT face=Arial color=#0000ff size=2>And
  another suggestion will be to do&nbsp;a 'make clean' whenever you try
  compiling mapserver...You could comment out portions under "clean" option that
  you dont want gone., (for </FONT></SPAN></DIV>
  size=2>example regex.o etc.,)</FONT></SPAN></DIV>
  <DIV><SPAN class=371015522-16042003><FONT face=Arial color=#0000ff size=2>This
  will ensure a "Rebuild all"</FONT></SPAN></DIV>
  size=2>Gayathri</FONT></SPAN></DIV>
  <BLOCKQUOTE>
    size=2>-----Original Message-----<BR><B>From:</B> Gautam Kumar
    [mailto:gautamleam at yahoo.com]<BR><B>Sent:</B> Wednesday, April 16, 2003 1:31
    PM<BR><B>To:</B> mapserver-users at lists.gis.umn.edu<BR><B>Subject:</B>
    [Mapserver-users] esri ascii file support<BR><BR></FONT></DIV>
    <DIV>I needed to get mapserver to read and display esri ascii files (.asc),
    and I was wondering how this was done? I had installed gdal 1.1.8&nbsp;as
    well because i read that was needed for ascii files but when i tried to
    configure mapserver to recognize that (./configure --with-gdal), and then
    ran make, it spat back (make: Nothing to be done for `all'.) I'm not sure
    what that was all about either. If anyone can help me with either of these
    two problems, that would be very appreciated. Thanks.</DIV>
    <P><BR>
    <HR SIZE=1>
    Do you Yahoo!?<BR><A
    href="http://us.rd.yahoo.com/search/mailsig/*http://search.yahoo.com">The
    New Yahoo! Search</A> - Faster. Easier.
Bingo.</BLOCKQUOTE></BLOCKQUOTE></BODY></HTML>
------_=_NextPart_001_01C3045E.B8C5BEF0--
