[Mapserver-users] RuntimeError: msSearchDiskTree(): Unable to access file.
Sven Jacobi
jacobi at dfki.de
Thu Apr 17 06:08:00 EDT 2003
Hi list,
I have following problem:
I want to create a layer with aerial photos, but these files are too
large so that I have to tile them.
I have done this in the chronological order:
1. use gdaltindex to create the shapefiles (test.dbf, test.shx and test.shp)
"/gdaltindex test.shp *.tif" /
It seemed to be correct, because with CGI there were no problems....
2. But when using Mapscript/Python. I received
"/RuntimeError: msSearchDiskTree(): Unable to access file."/
3. To get rid of this failure I decided to create a qix-file (I had a
similar failure in the past). Therefor I used shptree.
/"shptree test.shp"/
4. This works, but there is one problem: It only works once.
When I have written a new mapfile with my script, I get the same
runtime error as above. Although everything looks the same.
Could there be any conflict between qix-file and the shp-file generated
by gdaltindex. Both handle with indexing.
I have no ideas any more....
Any help?
Thanks in forward,
Sven
