[Mapserver-users] transparent layer example .map request
Charlton Purvis
cpurvis at asg.sc.edu
Thu Apr 17 10:56:23 EDT 2003
Thanks, Frank, but I'm still stuck.
Would you say that something like this should work?
MAP
TRANSPARENT ON
LAYER
NAME "elevation GIF"
END
LAYER
NAME "rainfall"
TRANSPARENCY 75
END
END
It doesn't work w/ my setup. The rainfall layer covers everything
underneath it.
-----Original Message-----
From: Frank Warmerdam [mailto:warmerdam at pobox.com]
Sent: Thursday, April 17, 2003 10:43 AM
To: Charlton Purvis
Subject: Re: [Mapserver-users] transparent layer example .map request
Charlton Purvis wrote:
> Hi, folks:
> I've looked through the archives, and I'm confused whether or not
3.6.3
> is transparent-happy. There are posts that include TRANPARENCY #.
> While others include TRANSPARENT ON. And others w/ TRANSPARENT TRUE.
> And 3.6.developemnt sounds transparent ready, but what about the
> official 3.6.3 release? I'm not ready for 3.7 (for some unknown
> reason).
> I've got an annual rainfall polygon layer that I'd like to overlay on
my
> elevation GIF. So the GIF should come shining through the rainfall
> layer. This might not be what I want (hashing, etc.), but I'd like to
> experiment, anyway.
> Would someone mind posting an example .map file while also including
> your MapServer version so I can make sure I'm talking apples to
apples?
Charlton,
There are two transparency issues, layer transparency which uses the
"TRANSPARENCY #" format to indicate the opacity (100=opaque) of a whole
layer. The other item is whether the output file is enabled for
transparency
support and this is at the MAP level using the TRANSPARENT keyword. It
takes
a boolean, of which various values are supported including TRUE/FALSE
and
ON/OFF.
Generally speaking transparency support is OK in 3.6.x as far as I know.
Best regards,
I set the clouds in motion - turn up | Frank Warmerdam,
and watch the world go round - Rush | Geospatial Programmer for Rent
