[Mapserver-users] MapServer compile issue
Joe Bussell
joe at otsys.com
Mon Apr 21 12:43:01 EDT 2003
what do you get when you type:
ldd mapserv
Sounds like a shared object is not linked correctly.
Cordially,
Joe Bussell
On Time Systems
www.trafficdodger.com
Tom.Kralidis at CCRS.NRCan.gc.ca wrote:
> Hi,
> In trying to build a distribution of MapServer (3.6.5), I run into the
> following errors. Here is my trail of the build:
> (latest png, zlib, jpeg, freetype2, gd2.0.12, proj, libwww).
> $ ./configure --with-proj=/usr/local/src/proj-4.4.7/
> --with-gdal=/usr/local/bin/gdal-config --wi
> th-ogr=/usr/local/src/gdal-1.1.8/ogr/
> --with-wmsclient=/usr/local/src/w3c-libwww-5.4.0/ --libdir=/usr/local/lib
> --includedir=/usr/local/include
> $ make
> $ ./mapserv
> ./mapserv: error in loading shared libraries: ./mapserv: undefined symbol:
> asStyleLabel
> I added the /usr/local/include and /usr/local/lib to the configure command
> because I was getting not found library type errors (looking for include /
> libs in /usr/, instead of /usr/local).
> I an trying to compile on RedHat Linux (6.2).
> Any idea what's going on here?
> Thanks
> ..Tom
> Tom Kralidis
> Systems Scientist
> Canada Centre for Remote Sensing
> Tel: (613) 947-1828
> http://www.cgdi.ca/
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
