[Mapserver-users] MapServer compile issue
Daniel Morissette
morissette at dmsolutions.ca
Mon Apr 21 13:31:28 EDT 2003
'asStyleLabel' comes from the OGR library, so I suspect a problem
related to GDAL/OGR. Looking at your configure command, I see that you
point configure to the OGR source but since you are building with
gdal-config this is not necessary and could be the origin of your
problems. I would suggest using instead:
--with-gdal=/usr/local/bin/gdal-config --with-ogr
Oh wait... I checked the ldd output that you sent in another message,
and it reports:
libgdal.1.1.so => /usr/lib/libgdal.1.1.so (0x4018b000)
It seems that you have duplicate versions of the gdal library: one copy
under /usr/local and one under /usr ... this is not good.
OK, here is what you should do:
1- Make sure you have one and only one copy of every support library
installed on your system. Ideally support libs that you build should be
installed under /usr/local/lib and /usr/local/include
2- Make sure /usr/local/bin is in your executable path, and that
/usr/local/lib is in your runtime library path
3- Point configure to the location where the libs are installed instead
of to their source, your configure command should become something like:
$ ./configure --with-proj=/usr/local/ \
--with-gdal=/usr/local/bin/gdal-config --with-ogr \
--with-wmsclient \
--libdir=/usr/local/lib --includedir=/usr/local/include
(I don't know what --libdir and --includedir do or if they will have any
real impact on your build)
I hope that helps,
Daniel
Tom.Kralidis at ccrs.nrcan.gc.ca wrote:
> Hi,
> In trying to build a distribution of MapServer (3.6.5), I run into the
> following errors. Here is my trail of the build:
> (latest png, zlib, jpeg, freetype2, gd2.0.12, proj, libwww).
> $ ./configure --with-proj=/usr/local/src/proj-4.4.7/
> th-ogr=/usr/local/src/gdal-1.1.8/ogr/
> --with-wmsclient=/usr/local/src/w3c-libwww-5.4.0/ --libdir=/usr/local/lib
> $ make
> $ ./mapserv
> ./mapserv: error in loading shared libraries: ./mapserv: undefined symbol:
> asStyleLabel
> I added the /usr/local/include and /usr/local/lib to the configure command
> because I was getting not found library type errors (looking for include /
> libs in /usr/, instead of /usr/local).
> I an trying to compile on RedHat Linux (6.2).
> Any idea what's going on here?
> Thanks
> ..Tom
> Tom Kralidis
> Systems Scientist
> Canada Centre for Remote Sensing
> Tel: (613) 947-1828
> http://www.cgdi.ca/
