[Mapserver-users] mapserver using grass raster
Heiko.Kehlenbrink at vermes.fh-oldenburg.de Heiko.Kehlenbrink at vermes.fh-oldenburg.de
Thu Apr 24 07:48:13 EDT 2003
Quoting Frank Warmerdam <warmerdam at pobox.com>:
hi frank,
thank you for your support,
using your advice i`ve got the mapserver-grass connection running.
> I am not sure why gdalinfo is finding the raster, but it isn't found
> in MapServer.  Are you use you are using the same GDAL for both?
yes there were only one gdal installation but as mentioned before 2 proj4 installations.
i struggled because the rpm i used from the freegis cd used an upper case PROJ4.. title
and my own builded a lower case (proj4...), mostly my fault...
> Any possibility of permissions problems?
nope...
> Most likely GDAL doesn't know how to use dlopen() in your build, and
> so
> can't dynamically load libproj.so.  Does your gdal/port/gdal_config.h
> file include "#define HAVE_LIBDL 1"?  If not, there was a configure
> problem.
No, cpl_config.h includes "#define HAVE_LIBDL 1"
> This seems to be related to gcc 3.x inclusion of /usr/local/include in
> the
> default include path.  Are you using GDAL 1.1.8?  I thought it was fixed
> in
> that.  Perhaps you could try again with a nightly snapshot of GDAL.
i had to erease both proj4 installations and reinstall
proj-4.4.7
doing so i could compile and install the gdal-cvs snapshoot against  libgrass
and grass raster files could be detected.
after putting the .grassrc5 in the /srv/www/htdocs/ directory (suse 8.1) i could access
the grass raster file from the mapfile via
LAYER
    NAME "test"
    STATUS DEFAULT
    TYPE RASTER
    DATA "earth8bit at world"
END
where world was the grass mapset.
best regards
heiko
