[Mapserver-users] QuerybyPoint no result (Help) PHP/Mapscript
jose.quintal at cfe.gob.mx jose.quintal at cfe.gob.mx
Thu Apr 24 19:34:56 EDT 2003
I have a data base in Mysql in which it contains ID, cor_x, cor_y and other
4 fields. The points in the map already visualize, but when wanting to do
query does not bring any result to me.
Here this part of the code where I select the registries of the data base
and I visualize them in the map .
mysql_select_db("mapas") or die("No selecciono la Base de Datos");
$sql="SELECT * from postes_Mer WHERE circuito = '$buscar' ";
$p=mysql_query($sql) or die("Error al Ejecutar la Consulta");
//Arma la consulta
//  get a layer object representing your pointlayer
$layerObj = undef;
$layerObj = $map->getLayerByName("postes");
// get a class object representing the first class in the layer
$classObj = $layerObj->getClass(0);
// create a new point object to hold the X Y data
 $pointObj = ms_newPointObj();
$i=0;
while($reg=mysql_fetch_array($p))
     $a=$reg['id'];
     $b=$reg['cor_x'];
     $c=$reg['cor_y'];
     //set the X Y values of the point object
     $pointObj->setXY($b,$c);
     $line = ms_newLineObj();
     $line ->add($pointObj);
     $shp = ms_newShapeObj(MS_SHAPE_POINT);
     $shp->add($line);
     //$shp->setBounds();
     $shp->{text} = $a;
     $shp->{index} = $i;
     if($layerObj->addFeature($shp) == -1){
             echo  "addFeature failed";
     $point_lookup[$i] = $a;
     $i++;
     $pointObj->draw($map, $layerObj, $image, 0, $a);
Here it is the part where I make the QuerybyPoint
if ( isset($HTTP_POST_VARS["mapa_x"]) && isset($HTTP_POST_VARS["mapa_y"]) )
$nClickGeoX = GMapPix2Geo($mapa_x, 0, $dfWidthPix,
                                $dfMinX, $dfMaxX, 0);
$nClickGeoY = GMapPix2Geo($$mapa_y, 0, $dfHeightPix,
                                    $dfMinY, $dfMaxY, 1);
  $ptClicked = ms_newPointObj();
  $ptClicked->setXY($nClickGeoX, $nClickGeoY);
  if ($info_pt == 1 )
    $record = -1;
    $layerObj = $map->getLayerByName('postes');
    $layerObj = @$map->queryByPoint ($ptClicked,MS_SINGLE,-1);
      if($layerObj == MS_SUCCESS)
       $results = $layerObj->{resultcache};
       $num_results = $results->{numresults};
  //   we only expect one result.
       $rslt = $layerObj->getResult(0);
//     this is an index into the point lookup table.
       $record = $rslt->{shapeindex};
       $point_name = $point_lookup[$record];
        echo "Encontrado " .  $point_name;
Here he is .map
MAP
  NAME "MER"
  STATUS ON
  EXTENT 217014 2.30865e+006 242281 2.33284e+006
  SIZE 800 600
  SHAPEPATH "c:/Php4/mapserver/webmap/shp/"
  SYMBOLSET "c:/Php4/mapserver/webmap/etc/symbols.sym"
  FONTSET "c:/Php4/mapserver/webmap/etc/fonts.txt"
  IMAGECOLOR 213 255 255
  TRANSPARENT OFF
  UNITS METERS
  INTERLACE ON
  IMAGETYPE PNG
  IMAGEQUALITY 150
  WEB
    IMAGEPATH "C:/tmp/ms_tmp/"
    IMAGEURL "/ms_tmp/"
  END
  QUERYMAP
    COLOR 255 255 0
    STYLE HILITE
  END
  LEGEND
    STATUS ON
    IMAGECOLOR 199 226 243
    TRANSPARENT TRUE
    INTERLACE TRUE
    POSITION LL
    KEYSIZE 18 2
    KEYSPACING 5 5
    LABEL
      TYPE BITMAP
      SIZE MEDIUM
      OFFSET 0 0
      BUFFER 0
      MINDISTANCE -1
      MINFEATURESIZE -1
      COLOR 0 0 89
      PARTIALS TRUE
      FORCE FALSE
    END
  END
  SCALEBAR
    STATUS ON
    COLOR 255 255 255
    OUTLINECOLOR 0 0 0
    BACKGROUNDCOLOR 0 0 0
    IMAGECOLOR 255 255 255
    TRANSPARENT FALSE
    UNITS KILOMETERS
    INTERVALS 5
    SIZE 300 5
    STYLE 0
    POSITION UC
    INTERLACE TRUE
    LABEL
      TYPE BITMAP
      SIZE SMALL
      OFFSET 0 0
      BUFFER 0
      MINDISTANCE -1
      MINFEATURESIZE -1
      COLOR 0 0 0
      PARTIALS TRUE
      FORCE FALSE
    END
  END
  LAYER
    NAME "MERTP"
    STATUS ON
    DATA "Merida"
    TYPE LINE
    UNITS METERS
    SIZEUNITS PIXELS
    TOLERANCE 3
    TOLERANCEUNITS PIXELS
    CLASS
      NAME "Cd de Merida"
      SYMBOL 0
     COLOR 102 153 204
#      COLOR 255 255 223
      OUTLINECOLOR 51 153 204
      SIZE 1
      MINSIZE 1
      MAXSIZE 100
    END
  END
  LAYER
    NAME "MerText"
    STATUS ON
    DATA "Mertext"
    TYPE POINT
    UNITS METERS
    SIZEUNITS PIXELS
    LABELITEM "NAME"
    LABELMINSCALE 5
    LABELMAXSCALE 30000
    TOLERANCE 3
    CLASS
      NAME "Nombre de Calles"
      SYMBOL 0
      COLOR 51 153 204
      SIZE 2
      MINSIZE 1
      MAXSIZE 100
      LABEL
        TYPE BITMAP
        SIZE SMALL
        POSITION CC
        OFFSET 0 0
        BUFFER 2
        MINDISTANCE -1
        MINFEATURESIZE -1
        COLOR 0 0 0
        PARTIALS TRUE
        FORCE FALSE
      END
    END
  END
LAYER
  NAME "postes"
  TYPE POINT
  STATUS ON
  TOLERANCE 10
  LABELMINSCALE 10
  LABELMAXSCALE 60000
  TEMPLATE "postes.html"
  CLASS
    SYMBOL 'circle'
    COLOR 255 89 89
    SIZE 10
    MINSIZE 5
    MAXSIZE 2
    LABEL
      ANTIALIAS TRUE
      TYPE TRUETYPE
      FONT Arialn
      SIZE 8
      POSITION CL
      BUFFER 2
      MINDISTANCE -3
      MINFEATURESIZE -1
      COLOR 252 152 54
      PARTIALS TRUE
      FORCE FALSE
    END
  END
 END
END
Thanks
Jose Antonio Quintal Castillo
PHP/Mapscript 4.2
MapServer version 3.6.3
Windows 2000 Server IIS
