[Mapserver-users] Mandrake 9 installation problems
Gerry Creager N5JXS
gerry.creager at tamu.edu
Fri Apr 25 08:22:37 EDT 2003
I saw similar warning in Redhat 9, but got a clean compile and a working
system. I suspect you do not have shapelib installed, or if so, it's
not referenced properly in /etc/ld.so.conf
gerry
Mark Balman wrote:
> Hi all
> Having read all the documentation and all the correspondence relating to the
> installation of Mapserver onto Mandrake 9 I am still stumped. Having
> "hopefully" installed all the necessary dependancies I can run ./configure
> with the following;
> ./configure \
> --with-proj \
> --with-gdal
> and this creates a Makefile ok without errors. My problem is when I run
> make, I get "loads" of messages specifically:
> changing search order for system directory "/usr/local/include" as it has
> already been specified as a non-system directory
> changing search order for system directory "/usr/include" as it has already
> make: *** [shp2img] Error 1
> As a newbie to linux, this is really puzzling, can anyone shed some
> light....
> TIA
> Mark
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
Gerry Creager -- gerry.creager at tamu.edu
Network Engineering -- AATLT, Texas A&M University
Cell: 979.229.5301 Office: 979.458.4020 FAX: 979.847.8578
Page: 979.228.0173
Office: 903A Eller Bldg, TAMU, College Station, TX 77843
