[Mapserver-users] Mandrake 9 installation problems
Vincent Schut schut at sarvision.com
Fri Apr 25 05:58:40 EDT 2003
Mark,
the messages about the include directories seem harmless to me. The error
should be generated by something else. Could you please attach the make
output, so I / we can have a look at that? (first 'make clean', then 'make >
make_out.txt' to redirect the output of make to a textfile instead of the
screen. Then attach this file 'make_out.txt'). You might want to send it to
the list and not only to me as it is almost weekend for me :-)
Regards,
Vincent Schut.
On Friday 25 April 2003 11:26, Mark Balman wrote:
> Hi all
> Having read all the documentation and all the correspondence relating to
> the installation of Mapserver onto Mandrake 9 I am still stumped. Having
> "hopefully" installed all the necessary dependancies I can run ./configure
> with the following;
> ./configure \
> --with-proj \
> --with-gdal
> and this creates a Makefile ok without errors. My problem is when I run
> make, I get "loads" of messages specifically:
> changing search order for system directory "/usr/local/include" as it has
> already been specified as a non-system directory
> changing search order for system directory "/usr/include" as it has already
> make: *** [shp2img] Error 1
> As a newbie to linux, this is really puzzling, can anyone shed some
> light....
> TIA
> Mark
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
______________________________________
Vincent Schut (schut at sarvision.com)
Sarvision B.V.
Wageningen, The Netherlands
www.sarvision.com
