[Mapserver-users] PostGIS subselect & where'd the data go?
Lowther, David W
dlowther at ou.edu
Fri Apr 25 10:22:24 EDT 2003
Charlton,
Try adding , * after the_geom to explicitly bring back all the rows in the
subselect. Like:
$layerObj->set("data","the_geom from "
. "(select oid, the_geom, * FROM se_bathy where 1=1) "
. "AS foo USING UNIQUE oid USING SRID=-1");
David Lowther
Software Engineer
GEO Information Systems
University of Oklahoma
dlowther at ou.edu
(405) 325-3131
http://www.geo.ou.edu
> -----Original Message-----
> From: Charlton Purvis [mailto:cpurvis at asg.sc.edu]
> Sent: Friday, April 25, 2003 9:14 AM
> To: mapserver-users at lists.gis.umn.edu
> Cc: jose.quintal at cfe.gob.mx
> Subject: [Mapserver-users] PostGIS subselect & where'd the data go?
> Sorry this is a lengthy post. I worked to keep the length
> down, but if you're interested in PostGIS-ing (or RDBMS-ing,
> for that matter) and subselecting, lend me your eyes.
> Problem: Once I add a WHERE clause (a subselect) to my
> PostGIS layer, I lose access to the data and only get the
> index (oid) back.
> Jose, this might be in line w/ your question from yesterday
> (Subject: [Mapserver-users] QuerybyPoint no result (Help)
> PHP/Mapscript), or it might not!
> ---- from Jose
> I have a data base in Mysql in which it contains ID, cor_x,
> cor_y and other 4 fields. The points in the map already
> visualize, but when wanting to do query does not bring any
> result to me.
> Here's the deal. I've got a PostGIS bathymetry line table.
> Indexed, etc.
> LAYER
> CONNECTION "user=postgres dbname=myGISdb host=localhost"
> CONNECTIONTYPE POSTGIS
> NAME "bathy_postgis"
> STATUS ON
> TYPE LINE
> TEMPLATE "dummy.html"
> METADATA
> "DESCRIPTION" "Bathyemetry"
> "RESULT_FIELDS" "DATASET SOURCE RES DEPTH_FT DEPTH_M DEPTH_FA"
> END
> CLASS
> COLOR 255 0 0
> END
> END
> Notice that there is no DATA definition. That's not a
> problem because I set that in my .php. Well, at least I
> don't *think* that is a problem.
> So here are the two cases that should have the same results but don't.
> // CONTROL (no subselecting)
> $layerObj->set("data","the_geom from se_bathy");
> // The TEST case is when I run my .php w/ this, instead:
> . "(select oid, the_geom FROM se_bathy where 1=1) "
> So, in theory, they should produce the same results. From
> the CONTROL group, I get all my columns returned. From the
> TEST, I just get the index. How do I know? I use this code
> to give me back some info:
> //$rect_extents has already been set
> $layerObj->queryByRect($rect_extents);
> // how many rows returned?
> echo "# results = " . $layerObj->getNumResults()
> . " from " . $layerObj->name . "<br>";
> // let's just look at the first row
> $layerObj->open();
> $oRes = $layerObj->getResult(0);
> $oShape = $layerObj->getShape(-1,$oRes->shapeindex);
> // pull out the column names & print 'em
> $ak = array_keys($oShape->values);
> echo "Data fields: | ";
> foreach ($ak as $val) {
> echo $val . " | ";
> And the results . . .
> CONTROL results
> # results = 739 from bathy_postgis
> Data fields: | gid | dataset | source | res | depth_ft |
> depth_m | depth_fa |
> TEST results
> Data fields: | oid |
> Interesting, eh? Something is getting masked when I do my
> subselecting and aliasing. What can I do to get back to my data?
> Why do I care? Why not use a FILTER? I will if I have to,
> but my middle initials are RDBMS, and if I can trim the data
> down at the database level before MapServer has to crunch it,
> I'm happy. Small datasets? No problem. Large datasets? Problem.
> Thanks for your time. MapServer rocks.
> Charlton
> Charlton Purvis
> (803) 777-8858 : voice
> (803) 777-8833 : fax
> cpurvis at sc.edu
> Advanced Solutions Group
> Department of Physics and Astronomy
> University of South Carolina
> Columbia, SC 29208
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/maps> erver-users
