[Mapserver-users] PostGIS subselect & where'd the data go?
Jan Hartmann
jhart at frw.uva.nl
Fri Apr 25 10:56:23 EDT 2003
Charlton,
When you put an SQL request to PostGIS using a table name, all fields
in that table are automatically returned to MapServer, alongside the
geometry field. That's why you see "dataset", "source", etc in the
result, although you did not specify them in the DATA statement. In a
subselect however, you have to request *every* field you need (including
oid). There is no default set of fields in a subselect.
Jan
Charlton Purvis wrote:
>So here are the two cases that should have the same results but don't.
>// CONTROL (no subselecting)
> $layerObj->set("data","the_geom from se_bathy");
>// The TEST case is when I run my .php w/ this, instead:
> $layerObj->set("data","the_geom from "
> . "(select oid, the_geom FROM se_bathy where 1=1) "
> . "AS foo USING UNIQUE oid USING SRID=-1");
>CONTROL results
># results = 739 from bathy_postgis
>Data fields: | gid | dataset | source | res | depth_ft | depth_m |
>depth_fa |
>TEST results
>Data fields: | oid |
Jan Hartmann
Department of Geography
University of Amsterdam
jhart at frw.uva.nl
