[Mapserver-users] is it possible to use relative coordinates for inline features?
Jeff Hoffmann
jeff at propertykey.com
Fri Apr 25 14:30:35 EDT 2003
Hopefully the question is clear, but if it's not, here's what I'm trying
to do: I want to place features in the lower right & center of a map.
I've basically copied a "copyright in the lower left corner" sample that
I found on the list & it works fine for me when I know the size of the
image that I'm creating. The problem is that I'm doing this with a WMS
layer which now needs to allow the caller to specify the image size &
those coordinates I figured out for the default image size aren't going
to work anymore. Is there any way that I can reference (or calculate)
the size in the mapfile to position the features in the right location?
Jeff Hoffmann
PropertyKey.com
