[Mapserver-users] Enhancement for tiling files in multiple coordinate systems
Brent Fraser bfraser at geoanalytic.com
Fri Apr 25 15:31:53 EDT 2003
This is a multi-part message in MIME format.
------=_NextPart_000_01CF_01C30B2F.087FAF60
Content-Type: text/plain;
	charset="iso-8859-1"
Content-Transfer-Encoding: quoted-printable
Ed, Paul, (and others),
  Thanks for the excellent suggestions!  Using the C preprocessor (or a =
similar menchanism) to automatically include the 10 to 20 layer =
definitions would solve my current problem, and I'll have to look into =
that. I think automatically generating map files has merit too and =
potentially offers lots of functionality above and beyond solving my =
problem.=20
  Ed, you hit the nail on the head with your maintenance comment.  We've =
got several Mapserver sites set up internally and we build sites for our =
customers too.  I like to minimize the amount of scripting for each site =
by using the native features of Mapserver whenever possible to reduce =
maintenance issues (hmmm, maybe I just write buggy scripts?).
    In this particular case, I'd rather look to enhancing Mapserver =
since I don't think it stresses the scope of Mapserver, and I doubt if =
it would require a lot of internal Mapserver code.  The other benefit is =
that others can make use of the functionality "out of the box" without =
having to do any scripting.
    On the other hand, maybe this problem is just too specialized and =
better left to scripting.  I don't want to add code (and complexity) to =
Mapserver if it's not solving a important problem.
Thanks again,
Brent
  ----- Original Message -----=20
  To: Brent Fraser ; mapserver-users=20
  Sent: Friday, April 25, 2003 12:12 PM
  Subject: RE: [Mapserver-users] Enhancement for tiling files in =
  Brent -
  Here are some thoughts:
  You seem to be moving the problem around more than actually =
eliminating it.  If the tileindex files are in a different coordinate =
system, then you either need a tool to generate reprojected tile indexes =
or you need to reproject the native-projection tileindex file after you =
make it.  Then you have to splice together the separate index files.  Or =
create a new tool that does the indexing, reprojection, and splicing all =
in one.
  Maintaining multiple layers like yours can be made much easier by =
automating the mapfile generation process.  As I've mentioned here =
before, we use the C preprocessor to generate the layers for all 27 UTM =
zones needed for complete USGS DRG coverage.  I've only got one set of =
zone definitions, and let the computer crank them all out.
  We've thought about tileindexes in different coordinate systems =
before, too.  I don't think there's much of a reason to NOT do it, but =
if the real issue is "how do I most easily maintain this setup?", the C =
preprocessor route works quite well.
      - Ed
  Ed McNierney
  President and Chief Mapmaker
  TopoZone.com / Maps a la carte, Inc.
  73 Princeton Street, Suite 305
  North Chelmsford, MA  01863
  ed at topozone.com
  (978) 251-4242=20
    -----Original Message-----
    From: Brent Fraser [mailto:bfraser at geoanalytic.com]
    Sent: Friday, April 25, 2003 1:50 PM
    To: mapserver-users
    Subject: [Mapserver-users] Enhancement for tiling files in multiple =
coordinate systems
    Mapserver users,
      I've got about 4 gb of U.S. topos (1:250k scale DRGs) .  My goal =
is to serve up the DRGs as one layer and have Mapserver reproject them =
on the fly when necessary to the UTM zone used for viewing (I'll be =
using scripting to determine which UTM zone to use for the user's =
current extent every time they pan or zoom).  Usually no reprojection =
will be required except when the user's extent is at the edge of a UTM =
zone.  My plan is to use the TILEINDEX feature to reference the raster =
data. Currently Mapserver requires the TILEINDEX shapefile to be in the =
same coordinate system as the data it references.
      One option, given the current capabilities of Mapserver, is to =
have one layer for each UTM zone.  In the U.S. that would mean about 10 =
layer definitions, not too bad but I may eventually have some other data =
covering 16 zones (or all 60!).  Too many layer definitions would be a =
maintenance problem I'd like to avoid.
        Another option would be to pre-condition the raster data by =
reprojecting it to geographic coordinates.  This would allow one =
tileindex file and therefore one layer definition.  But the result is =
that the raster data would always be re-projected on the fly by =
Mapserver (since the display projection would be UTM) and performance =
would suffer.
      A solution might be enhance Mapserver to allow the tileindex =
shapefile to be in geographic coords while using the "PROJECTION AUTO" =
feature to determine the coordinate system of the data file.  That would =
require two projection definitions in one layer: one for the tileindex =
(proj=3Dlatlong) and one for the data (AUTO) requiring either a change =
to structure of the map file or the addition of keywords.  How about =
replacing TILEINDEX and TILEITEM with a TILE object containing INDEX, =
ITEM, and PROJECTION?  Any other ideas?
    Thanks!
    Brent Fraser
    GeoAnalytic Inc.
    Tel:(403) 213-2700
    www.geoanalytic.com
Content-Type: text/html;
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.0 Transitional//EN">
<HTML><HEAD>
<META http-equiv=3DContent-Type content=3D"text/html; =
charset=3Diso-8859-1">
<META content=3D"MSHTML 6.00.2600.0" name=3DGENERATOR>
<STYLE></STYLE>
</HEAD>
<BODY bgColor=3D#ffffff>
<DIV><FONT face=3DArial size=3D2>Ed, Paul, (and others),</FONT></DIV>
<DIV><FONT face=3DArial size=3D2></FONT>&nbsp;</DIV>
<DIV><FONT face=3DArial size=3D2>&nbsp; Thanks for the excellent =
suggestions!&nbsp;=20
Using the C preprocessor (or a similar menchanism) to automatically =
include the=20
10 to 20 layer definitions would solve my current problem, and I'll have =
to look=20
into that. </FONT><FONT face=3DArial size=3D2>I think automatically =
generating map=20
files has merit too and potentially offers lots of functionality above =
and=20
beyond solving my problem.&nbsp;</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>&nbsp;&nbsp;Ed, you hit the nail on the =
head with=20
your maintenance comment.&nbsp; We've got several Mapserver sites set up =
internally and we build sites for our customers too.&nbsp; I like to =
minimize=20
the amount of scripting for each site by using the native features of =
Mapserver=20
whenever possible to reduce maintenance issues (hmmm, maybe&nbsp;I just =
write=20
buggy scripts?).</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>&nbsp;&nbsp;&nbsp; In this particular=20
case,&nbsp;I</FONT><FONT face=3DArial size=3D2>'d rather look to =
enhancing Mapserver=20
it would=20
require a lot of internal Mapserver code.&nbsp; The other benefit is =
that others=20
can make use of the functionality "out of the box" without having to do =
any=20
scripting.</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>&nbsp;&nbsp;&nbsp; On the other hand, =
maybe this=20
problem is just too specialized and better left to scripting.&nbsp; I =
don't want=20
to add code (and complexity) to Mapserver if it's not solving&nbsp;a =
important=20
problem.</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>Thanks again,</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>Brent</FONT></DIV>
<BLOCKQUOTE dir=3Dltr=20
style=3D"PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; =
BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
  <DIV style=3D"FONT: 10pt arial">----- Original Message ----- </DIV>
  <DIV=20
  style=3D"BACKGROUND: #e4e4e4; FONT: 10pt arial; font-color: =
black"><B>From:</B>=20
  <A title=3Ded at topozone.com href=3D"mailto:ed at topozone.com">Ed =
McNierney</A> </DIV>
  <DIV style=3D"FONT: 10pt arial"><B>To:</B> <A =
title=3Dbfraser at geoanalytic.com=20
  href=3D"mailto:bfraser at geoanalytic.com">Brent Fraser</A> ; <A=20
  title=3Dmapserver-users at lists.gis.umn.edu=20
  href=3D"mailto:mapserver-users at lists.gis.umn.edu">mapserver-users</A> =
</DIV>
  <DIV style=3D"FONT: 10pt arial"><B>Sent:</B> Friday, April 25, 2003 =
12:12=20
  PM</DIV>
  <DIV style=3D"FONT: 10pt arial"><B>Subject:</B> RE: [Mapserver-users]=20
  Enhancement for tiling files in multiple coordinate systems</DIV>
  <DIV><BR></DIV>
  <DIV><SPAN class=3D500025817-25042003><FONT face=3DArial =
color=3D#0000ff=20
  size=3D2>Brent -</FONT></SPAN></DIV>
color=3D#0000ff=20
  size=3D2></FONT></SPAN>&nbsp;</DIV>
color=3D#0000ff size=3D2>Here=20
  are some thoughts:</FONT></SPAN></DIV>
color=3D#0000ff=20
color=3D#0000ff size=3D2>You=20
  seem to be moving the problem around more than actually eliminating =
it.&nbsp;=20
  If the tileindex files are in a different coordinate system, then you =
either=20
  need a tool to generate reprojected tile indexes or you need to =
reproject the=20
  native-projection tileindex file after you make it.&nbsp; Then you =
have to=20
  splice together the separate index files.&nbsp; Or create a new tool =
that does=20
  the indexing, reprojection, and splicing all in =
one.</FONT></SPAN></DIV>
color=3D#0000ff=20
color=3D#0000ff=20
  size=3D2>Maintaining multiple layers like yours can be made much =
easier by=20
  automating the mapfile generation process.&nbsp; As I've mentioned =
here=20
  before, we use the C preprocessor to generate the layers for all 27 =
UTM zones=20
  needed for complete USGS DRG coverage.&nbsp; I've only got one set of =
zone=20
  definitions, and let the computer crank them all =
out.</FONT></SPAN></DIV>
color=3D#0000ff=20
color=3D#0000ff=20
  size=3D2>We've thought about tileindexes in different coordinate =
systems before,=20
  too.&nbsp; I don't think there's much of a reason to NOT do it, but if =
the=20
preprocessor=20
  route works quite well.</FONT></SPAN></DIV>
color=3D#0000ff=20
  <DIV><SPAN class=3D500025817-25042003>&nbsp;&nbsp;&nbsp; <FONT =
face=3DArial=20
  color=3D#0000ff size=3D2>- Ed</FONT></SPAN></DIV>
  <P><FONT size=3D2>Ed McNierney<BR>President and Chief =
Mapmaker<BR>TopoZone.com /=20
  Maps a la carte, Inc.<BR>73 Princeton Street, Suite 305<BR>North =
Chelmsford,=20
  MA&nbsp; 01863<BR>ed at topozone.com<BR>(978) 251-4242 =
</FONT></P></SPAN></DIV>
  <BLOCKQUOTE dir=3Dltr style=3D"MARGIN-RIGHT: 0px">
    <DIV class=3DOutlookMessageHeader dir=3Dltr align=3Dleft><FONT =
face=3DTahoma=20
    size=3D2>-----Original Message-----<BR><B>From:</B> Brent Fraser=20
    [mailto:bfraser at geoanalytic.com]<BR><B>Sent:</B> Friday, April 25, =
2003 1:50=20
    PM<BR><B>To:</B> mapserver-users<BR><B>Subject:</B> =
    Enhancement for tiling files in multiple coordinate=20
    systems<BR><BR></FONT></DIV>
    <DIV><FONT face=3DArial size=3D2>Mapserver users,</FONT></DIV>
    <DIV><FONT face=3DArial size=3D2>&nbsp; I've got about 4 gb of U.S. =
topos=20
    (1:250k scale&nbsp;DRGs) .&nbsp; My goal is to serve up the DRGs as =
one=20
    layer and have Mapserver reproject them on the fly when necessary to =
the UTM=20
    zone used for viewing (I'll be using scripting to determine which =
UTM zone=20
    to use for the user's current extent every time they pan or =
zoom).&nbsp;=20
    Usually no reprojection will be required except when the user's =
extent is at=20
    the edge of a UTM zone.&nbsp; My plan is to use the TILEINDEX =
feature to=20
    reference the raster data. Currently Mapserver requires the =
TILEINDEX=20
    shapefile to be in the same coordinate system as the data it=20
    references.</FONT></DIV>
    <DIV><FONT face=3DArial size=3D2>&nbsp; One option, given the =
current=20
    capabilities of Mapserver, is to have one layer for each UTM =
zone.&nbsp; In=20
    the U.S. that would mean about 10 layer definitions, not too bad but =
I may=20
    eventually have some other data covering 16 zones (or all =
60!).&nbsp; Too=20
    many layer definitions would be a maintenance problem I'd like to=20
    avoid.</FONT></DIV>
    <DIV><FONT face=3DArial size=3D2>&nbsp;&nbsp;&nbsp; Another option =
would be to=20
    pre-condition the raster data by reprojecting it to geographic=20
    coordinates.&nbsp; This would allow one tileindex file and therefore =
one=20
    layer definition.&nbsp; But the result is that the raster data would =
always=20
    be re-projected on the fly by Mapserver (since the display =
projection would=20
    be UTM) and performance would suffer.</FONT></DIV>
    <DIV><FONT face=3DArial size=3D2>&nbsp; A solution might be enhance =
Mapserver to=20
    allow the tileindex shapefile to be in geographic coords while using =
the=20
    "PROJECTION AUTO" feature to determine the coordinate system of the =
data=20
    file.&nbsp; That would require two projection definitions in one =
layer: one=20
    for the tileindex (proj=3Dlatlong) and one for the data (AUTO)=20
    requiring&nbsp;either a change to structure of the&nbsp;map file or =
the=20
    addition of keywords.&nbsp; How about replacing TILEINDEX and =
TILEITEM with=20
    a TILE object&nbsp;containing INDEX, ITEM, and PROJECTION?&nbsp; Any =
other=20
    ideas?</FONT></DIV>
    <DIV><FONT face=3DArial size=3D2>Thanks!</FONT></DIV>
    <DIV><FONT face=3DArial size=3D2>Brent Fraser</FONT></DIV>
    <DIV><FONT face=3DArial size=3D2>GeoAnalytic Inc.<BR>Tel:(403) =
213-2700<BR><A=20
href=3D"mailto:bfraser at geoanalytic.com">bfraser at geoanalytic.com</A><BR><A=
=20
href=3D"http://www.geoanalytic.com">www.geoanalytic.com</A></FONT></DIV><=
/BLOCKQUOTE></BLOCKQUOTE></BODY></HTML>
------=_NextPart_000_01CF_01C30B2F.087FAF60--
