[Mapserver-users] installation problem
    Babak Toloue Tehrani
    babak.tehrani at geosysnet.de
    Sat Apr 26 12:29:53 PDT 2003
Edit your Makefile and add "-lstdc++" as shown below to the end of the
variable named "STATIC_LIBS"
STATIC_LIBS= $(GD_STATIC) $(OGR_STATIC) -lstdc++
Am Sam, 2003-04-26 um 08.18 schrieb sanjay tiwary:
> Hi
>    I am first time user of mapserver and getting problem in installing
> the mapserver.I have attached the screen display while running
> ./configure and make command as i am installing it on unix(Red hat).I
> have php(v4) and apache preinstalled and i have configured Apache as
> it is guided at http://mapserver.gis.umn.edu .Please help.
>                                                            sanjay
> [image]Catch all the cricket action. Download Yahoo! Score tracker
> ______________________________________________________________________
> checking how to run the C preprocessor... gcc -E
> checking for ANSI C header files... yes
> checking for strcasecmp... yes
> checking for strncasecmp... yes
> checking for strdup... yes
> checking whether we should include JPEG support...
> checking for jpeg_read_header in -ljpeg... yes
>         using libjpeg from system libs.
> checking which version of GD to use...
>         using libgd from system libs.
> checking where FreeType is installed...
> checking for FT_Init_FreeType in -lfreetype... yes
>         using libfreetype -lfreetype from system libs.
> checking where Zlib is installed...
> checking for zlibVersion in -lz... yes
>         using libz from system libs.
> checking where PNG is installed...
> checking for png_init_io in -lpng... yes
>         using libpng from system libs.
> checking for gdImageCreate in -lgd... yes
> checking for gdImageGif in -lgd... no
> checking for gdImagePng in -lgd... yes
> checking for gdImageJpeg in -lgd... yes
> checking for gdImageWBMP in -lgd... yes
> checking for gdImageStringFT in -lgd... yes
> checking for gdImageString16 in -lgd... yes
> checking for gdImageGifPtr in -lgd... no
>         using GD ( -DUSE_GD_PNG -DUSE_GD_JPEG -DUSE_GD_WBMP -DUSE_GD_FT) from system libs.
> checking whether we should include PDF support...
> checking for PDF_setlinewidth in -lpdf... no
> checking for PDF_setrgbcolor in -lpdf... no
> checking for PDF_moveto in -lpdf... no
> checking for PDF_curveto in -lpdf... no
> checking for PDF_show_xy in -lpdf... no
>         libpdf not found... PDF support not included.
> checking whether we should include TIFF support...
> checking for TIFFOpen in -ltiff... yes
>         using libtiff from system libs.
> checking whether we should include EPPL7 support...
>         including EPPL7 support.
> checking whether we should include PROJ.4 support...
>         PROJ.4 support not requested.
> checking whether we should include thread safe support...
>         thread safe support disabled.
> checking whether we should include ESRI SDE support...
>         ESRI SDE support not requested.
> checking whether we should compile in MPATROL support...
>         MPATROL support not requested.
> checking whether we should include OGR support...
>         OGR support not requested.
> checking if GDAL support requested... no
> checking if PostGIS support requested... no
> checking if OracleSpatial support requested... no
> checking whether we should include WMS support...
>         OGC WMS Compatibility not enabled (PROJ.4 is required for WMS).
> checking whether we should include WMS Client Connections support...
>         OGC WMS Client Connections not enabled (PROJ.4 and libwww required).
> Compiling with -DIGNORE_MISSING_DATA.
> checking whether we should enable debug features...
> checking for PHP/MapScript module options...
>         PHP/MapScript module not configured.
> updating cache ./config.cache
> creating ./config.status
> creating Makefile
> [root at cgg141 mapserver-3.6.4]# make
> gcc -c -O2  -Wall -DIGNORE_MISSING_DATA  -DUSE_EPPL    -DUSE_TIFF -DUSE_JPEG -DUSE_GD_PNG -DUSE_GD_JPEG -DUSE_GD_WBMP -DUSE_GD_FT        -I/usr/include              maptemplate.c -o maptemplate.o
> cc1: warning: changing search order for system directory "/usr/include"
> cc1: warning:   as it has already been specified as a non-system directory
> gcc -c -O2  -Wall -DIGNORE_MISSING_DATA  -DUSE_EPPL    -DUSE_TIFF -DUSE_JPEG -DUSE_GD_PNG -DUSE_GD_JPEG -DUSE_GD_WBMP -DUSE_GD_FT        -I/usr/include              mapbits.c -o mapbits.o
> gcc -c -O2  -Wall -DIGNORE_MISSING_DATA  -DUSE_EPPL    -DUSE_TIFF -DUSE_JPEG -DUSE_GD_PNG -DUSE_GD_JPEG -DUSE_GD_WBMP -DUSE_GD_FT        -I/usr/include              maphash.c -o maphash.o
> gcc -c -O2  -Wall -DIGNORE_MISSING_DATA  -DUSE_EPPL    -DUSE_TIFF -DUSE_JPEG -DUSE_GD_PNG -DUSE_GD_JPEG -DUSE_GD_WBMP -DUSE_GD_FT        -I/usr/include              mapshape.c -o mapshape.o
> gcc -c -O2  -Wall -DIGNORE_MISSING_DATA  -DUSE_EPPL    -DUSE_TIFF -DUSE_JPEG -DUSE_GD_PNG -DUSE_GD_JPEG -DUSE_GD_WBMP -DUSE_GD_FT        -I/usr/include              mapxbase.c -o mapxbase.o
> gcc -c -O2  -Wall -DIGNORE_MISSING_DATA  -DUSE_EPPL    -DUSE_TIFF -DUSE_JPEG -DUSE_GD_PNG -DUSE_GD_JPEG -DUSE_GD_WBMP -DUSE_GD_FT        -I/usr/include              mapparser.c -o mapparser.o
> gcc -c -O2  -Wall -DIGNORE_MISSING_DATA  -DUSE_EPPL    -DUSE_TIFF -DUSE_JPEG -DUSE_GD_PNG -DUSE_GD_JPEG -DUSE_GD_WBMP -DUSE_GD_FT        -I/usr/include              maplexer.c -o maplexer.o
> maplexer.c:3292: warning: `yyunput' defined but not used
> gcc -c -O2  -Wall -DIGNORE_MISSING_DATA  -DUSE_EPPL    -DUSE_TIFF -DUSE_JPEG -DUSE_GD_PNG -DUSE_GD_JPEG -DUSE_GD_WBMP -DUSE_GD_FT        -I/usr/include              maptree.c -o maptree.o
> gcc -c -O2  -Wall -DIGNORE_MISSING_DATA  -DUSE_EPPL    -DUSE_TIFF -DUSE_JPEG -DUSE_GD_PNG -DUSE_GD_JPEG -DUSE_GD_WBMP -DUSE_GD_FT        -I/usr/include              mapsearch.c -o mapsearch.o
> gcc -c -O2  -Wall -DIGNORE_MISSING_DATA  -DUSE_EPPL    -DUSE_TIFF -DUSE_JPEG -DUSE_GD_PNG -DUSE_GD_JPEG -DUSE_GD_WBMP -DUSE_GD_FT        -I/usr/include              mapstring.c -o mapstring.o
> gcc -c -O2  -Wall -DIGNORE_MISSING_DATA  -DUSE_EPPL    -DUSE_TIFF -DUSE_JPEG -DUSE_GD_PNG -DUSE_GD_JPEG -DUSE_GD_WBMP -DUSE_GD_FT        -I/usr/include              mapsymbol.c -o mapsymbol.o
> gcc -c -O2  -Wall -DIGNORE_MISSING_DATA  -DUSE_EPPL    -DUSE_TIFF -DUSE_JPEG -DUSE_GD_PNG -DUSE_GD_JPEG -DUSE_GD_WBMP -DUSE_GD_FT        -I/usr/include              mapfile.c -o mapfile.o
> gcc -c -O2  -Wall -DIGNORE_MISSING_DATA  -DUSE_EPPL    -DUSE_TIFF -DUSE_JPEG -DUSE_GD_PNG -DUSE_GD_JPEG -DUSE_GD_WBMP -DUSE_GD_FT        -I/usr/include              maplegend.c -o maplegend.o
> gcc -c -O2  -Wall -DIGNORE_MISSING_DATA  -DUSE_EPPL    -DUSE_TIFF -DUSE_JPEG -DUSE_GD_PNG -DUSE_GD_JPEG -DUSE_GD_WBMP -DUSE_GD_FT        -I/usr/include              maputil.c -o maputil.o
> gcc -c -O2  -Wall -DIGNORE_MISSING_DATA  -DUSE_EPPL    -DUSE_TIFF -DUSE_JPEG -DUSE_GD_PNG -DUSE_GD_JPEG -DUSE_GD_WBMP -DUSE_GD_FT        -I/usr/include              mapscale.c -o mapscale.o
> gcc -c -O2  -Wall -DIGNORE_MISSING_DATA  -DUSE_EPPL    -DUSE_TIFF -DUSE_JPEG -DUSE_GD_PNG -DUSE_GD_JPEG -DUSE_GD_WBMP -DUSE_GD_FT        -I/usr/include              mapquery.c -o mapquery.o
> gcc -c -O2  -Wall -DIGNORE_MISSING_DATA  -DUSE_EPPL    -DUSE_TIFF -DUSE_JPEG -DUSE_GD_PNG -DUSE_GD_JPEG -DUSE_GD_WBMP -DUSE_GD_FT        -I/usr/include              maplabel.c -o maplabel.o
> gcc -c -O2  -Wall -DIGNORE_MISSING_DATA  -DUSE_EPPL    -DUSE_TIFF -DUSE_JPEG -DUSE_GD_PNG -DUSE_GD_JPEG -DUSE_GD_WBMP -DUSE_GD_FT        -I/usr/include              maperror.c -o maperror.o
> gcc -c -O2  -Wall -DIGNORE_MISSING_DATA  -DUSE_EPPL    -DUSE_TIFF -DUSE_JPEG -DUSE_GD_PNG -DUSE_GD_JPEG -DUSE_GD_WBMP -DUSE_GD_FT        -I/usr/include              mapprimitive.c -o mapprimitive.o
> mapprimitive.c: In function `msImageCartographicPolyline':
> mapprimitive.c:1102: warning: unused variable `intersect_points'
> mapprimitive.c:1099: warning: `last_angle' might be used uninitialized in this function
> /usr/include/bits/mathinline.h: At top level:
> mapprimitive.c:771: warning: `get_centroid' defined but not used
> gcc -c -O2  -Wall -DIGNORE_MISSING_DATA  -DUSE_EPPL    -DUSE_TIFF -DUSE_JPEG -DUSE_GD_PNG -DUSE_GD_JPEG -DUSE_GD_WBMP -DUSE_GD_FT        -I/usr/include              mapproject.c -o mapproject.o
> mapproject.c: In function `msGetEPSGProj':
> mapproject.c:432: warning: return makes pointer from integer without a cast
> gcc -c -O2  -Wall -DIGNORE_MISSING_DATA  -DUSE_EPPL    -DUSE_TIFF -DUSE_JPEG -DUSE_GD_PNG -DUSE_GD_JPEG -DUSE_GD_WBMP -DUSE_GD_FT        -I/usr/include              mapraster.c -o mapraster.o
> gcc -c -O2  -Wall -DIGNORE_MISSING_DATA  -DUSE_EPPL    -DUSE_TIFF -DUSE_JPEG -DUSE_GD_PNG -DUSE_GD_JPEG -DUSE_GD_WBMP -DUSE_GD_FT        -I/usr/include              mapsde.c -o mapsde.o
> c++ -c -O2  -Wall -DIGNORE_MISSING_DATA  -DUSE_EPPL    -DUSE_TIFF -DUSE_JPEG -DUSE_GD_PNG -DUSE_GD_JPEG -DUSE_GD_WBMP -DUSE_GD_FT        -I/usr/include              mapogr.cpp -o mapogr.o
> cc1plus: warning: changing search order for system directory "/usr/include"
> cc1plus: warning:   as it has already been specified as a non-system directory
> gcc -c -O2  -Wall -DIGNORE_MISSING_DATA  -DUSE_EPPL    -DUSE_TIFF -DUSE_JPEG -DUSE_GD_PNG -DUSE_GD_JPEG -DUSE_GD_WBMP -DUSE_GD_FT        -I/usr/include              mappostgis.c -o mappostgis.o
> gcc -c -O2  -Wall -DIGNORE_MISSING_DATA  -DUSE_EPPL    -DUSE_TIFF -DUSE_JPEG -DUSE_GD_PNG -DUSE_GD_JPEG -DUSE_GD_WBMP -DUSE_GD_FT        -I/usr/include              maplayer.c -o maplayer.o
> gcc -c -O2  -Wall -DIGNORE_MISSING_DATA  -DUSE_EPPL    -DUSE_TIFF -DUSE_JPEG -DUSE_GD_PNG -DUSE_GD_JPEG -DUSE_GD_WBMP -DUSE_GD_FT        -I/usr/include              mapresample.c -o mapresample.o
> mapresample.c:419: warning: `msInitApproxTransformer' defined but not used
> mapresample.c:436: warning: `msFreeApproxTransformer' defined but not used
> mapresample.c:447: warning: `msApproxTransformer' defined but not used
> mapresample.c:551: warning: `msTransformMapToSource' defined but not used
> gcc -c -O2  -Wall -DIGNORE_MISSING_DATA  -DUSE_EPPL    -DUSE_TIFF -DUSE_JPEG -DUSE_GD_PNG -DUSE_GD_JPEG -DUSE_GD_WBMP -DUSE_GD_FT        -I/usr/include              mapwms.c -o mapwms.o
> maptemplate.h:16: warning: `inchesPerUnit' defined but not used
> gcc -c -O2  -Wall -DIGNORE_MISSING_DATA  -DUSE_EPPL    -DUSE_TIFF -DUSE_JPEG -DUSE_GD_PNG -DUSE_GD_JPEG -DUSE_GD_WBMP -DUSE_GD_FT        -I/usr/include              mapwmslayer.c -o mapwmslayer.o
> gcc -c -O2  -Wall -DIGNORE_MISSING_DATA  -DUSE_EPPL    -DUSE_TIFF -DUSE_JPEG -DUSE_GD_PNG -DUSE_GD_JPEG -DUSE_GD_WBMP -DUSE_GD_FT        -I/usr/include              maporaclespatial.c -o maporaclespatial.o
> gcc -c -O2  -Wall -DIGNORE_MISSING_DATA  -DUSE_EPPL    -DUSE_TIFF -DUSE_JPEG -DUSE_GD_PNG -DUSE_GD_JPEG -DUSE_GD_WBMP -DUSE_GD_FT        -I/usr/include              mapgml.c -o mapgml.o
> gcc -c -O2  -Wall -DIGNORE_MISSING_DATA  -DUSE_EPPL    -DUSE_TIFF -DUSE_JPEG -DUSE_GD_PNG -DUSE_GD_JPEG -DUSE_GD_WBMP -DUSE_GD_FT        -I/usr/include              mapprojhack.c -o mapprojhack.o
> mapprojhack.c:71: warning: `ConvertProjUnitStringToMS' defined but not used
> gcc -c -O2  -Wall -DIGNORE_MISSING_DATA  -DUSE_EPPL    -DUSE_TIFF -DUSE_JPEG -DUSE_GD_PNG -DUSE_GD_JPEG -DUSE_GD_WBMP -DUSE_GD_FT        -I/usr/include              mapthread.c -o mapthread.o
> gcc -c -O2  -Wall -DIGNORE_MISSING_DATA  -DUSE_EPPL    -DUSE_TIFF -DUSE_JPEG -DUSE_GD_PNG -DUSE_GD_JPEG -DUSE_GD_WBMP -DUSE_GD_FT        -I/usr/include              epplib.c -o epplib.o
> ar rc libmap.a maptemplate.o mapbits.o maphash.o mapshape.o mapxbase.o mapparser.o maplexer.o maptree.o mapsearch.o mapstring.o mapsymbol.o mapfile.o maplegend.o maputil.o mapscale.o mapquery.o maplabel.o maperror.o mapprimitive.o mapproject.o mapraster.o mapsde.o mapogr.o mappostgis.o maplayer.o mapresample.o mapwms.o mapwmslayer.o maporaclespatial.o mapgml.o mapprojhack.o mapthread.o epplib.o
> ranlib libmap.a
> gcc -c -O2  -Wall -DIGNORE_MISSING_DATA  -DUSE_EPPL    -DUSE_TIFF -DUSE_JPEG -DUSE_GD_PNG -DUSE_GD_JPEG -DUSE_GD_WBMP -DUSE_GD_FT        -I/usr/include              shp2img.c -o shp2img.o
> gcc -O2  -Wall -DIGNORE_MISSING_DATA  -DUSE_EPPL    -DUSE_TIFF -DUSE_JPEG -DUSE_GD_PNG -DUSE_GD_JPEG -DUSE_GD_WBMP -DUSE_GD_FT        -I/usr/include              shp2img.o  -L. -lmap -lgd -L/usr/lib -lgd -ljpeg -lfreetype -lpng -lz  -ltiff -ljpeg -lfreetype -lpng -lz  -ljpeg          -lm   -o shp2img
> ./libmap.a(mapogr.o)(.eh_frame+0x11): undefined reference to `__gxx_personality_v0'
> collect2: ld returned 1 exit status
Babak Toloue Tehrani <babak.tehrani at geosysnet.de>
More information about the MapServer-users
