[Mapserver-users] installation problem
sanjay tiwary sanjaykumartiwary44 at yahoo.co.in
Sat Apr 26 02:06:47 EDT 2003
--0-1437825122-1051337207=:26453
Content-Type: multipart/alternative; boundary="0-745353076-1051337207=:26453"
--0-745353076-1051337207=:26453
Content-Type: text/plain; charset=iso-8859-1
Content-Transfer-Encoding: 8bit
hi   I am a first timer mapserver user.I have PHP(version-4.3) ,Apache installed on the server (Unix).I am trying to install mapserver but while running make command i am getting one error.The text file attached has the complete screen displys.Please help me.        Sanjay
Catch all the cricket action. Download Yahoo! Score tracker
Content-Type: text/html; charset=iso-8859-1
<DIV>
<DIV>
<DIV>hi</DIV>
<DIV>&nbsp;&nbsp; I am a first timer mapserver user.I have PHP(version-4.3) ,Apache installed on the server (Unix).I am trying to install mapserver but while running make command i am getting one error.The text file attached has the complete&nbsp;screen displys.Please help me.</DIV>
<DIV>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; Sanjay&nbsp;</DIV></DIV></DIV><p><img src="http://sg.yimg.com/i/aa/icons/28/cricket.gif" height=28 width=28>
Catch all the cricket action. Download <a href="http://in.sports.yahoo.com/cricket/tracker.html" target="_blank">
Yahoo! Score tracker</a>
--0-745353076-1051337207=:26453--
Content-Type: text/plain; name="screen.txt"
Content-Description: screen.txt
Content-Disposition: inline; filename="screen.txt"
checking how to run the C preprocessor... gcc -E
checking for ANSI C header files... yes
checking for strcasecmp... yes
checking for strncasecmp... yes
checking for strdup... yes
checking whether we should include JPEG support...
checking for jpeg_read_header in -ljpeg... yes
        using libjpeg from system libs.
checking which version of GD to use...
        using libgd from system libs.
checking where FreeType is installed...
checking for FT_Init_FreeType in -lfreetype... yes
        using libfreetype -lfreetype from system libs.
checking where Zlib is installed...
checking for zlibVersion in -lz... yes
        using libz from system libs.
checking where PNG is installed...
checking for png_init_io in -lpng... yes
        using libpng from system libs.
checking for gdImageCreate in -lgd... yes
checking for gdImageGif in -lgd... no
checking for gdImagePng in -lgd... yes
checking for gdImageJpeg in -lgd... yes
checking for gdImageWBMP in -lgd... yes
checking for gdImageStringFT in -lgd... yes
checking for gdImageString16 in -lgd... yes
checking for gdImageGifPtr in -lgd... no
        using GD ( -DUSE_GD_PNG -DUSE_GD_JPEG -DUSE_GD_WBMP -DUSE_GD_FT) from system libs.
checking whether we should include PDF support...
checking for PDF_setlinewidth in -lpdf... no
checking for PDF_setrgbcolor in -lpdf... no
checking for PDF_moveto in -lpdf... no
checking for PDF_curveto in -lpdf... no
checking for PDF_show_xy in -lpdf... no
        libpdf not found... PDF support not included.
checking whether we should include TIFF support...
checking for TIFFOpen in -ltiff... yes
        using libtiff from system libs.
checking whether we should include EPPL7 support...
        including EPPL7 support.
checking whether we should include PROJ.4 support...
        PROJ.4 support not requested.
checking whether we should include thread safe support...
        thread safe support disabled.
checking whether we should include ESRI SDE support...
        ESRI SDE support not requested.
checking whether we should compile in MPATROL support...
        MPATROL support not requested.
checking whether we should include OGR support...
        OGR support not requested.
checking if GDAL support requested... no
checking if PostGIS support requested... no
checking if OracleSpatial support requested... no
checking whether we should include WMS support...
        OGC WMS Compatibility not enabled (PROJ.4 is required for WMS).
checking whether we should include WMS Client Connections support...
        OGC WMS Client Connections not enabled (PROJ.4 and libwww required).
Compiling with -DIGNORE_MISSING_DATA.
checking whether we should enable debug features...
checking for PHP/MapScript module options...
        PHP/MapScript module not configured.
updating cache ./config.cache
creating ./config.status
creating Makefile
[root at cgg141 mapserver-3.6.4]# make
gcc -c -O2  -Wall -DIGNORE_MISSING_DATA  -DUSE_EPPL    -DUSE_TIFF -DUSE_JPEG -DUSE_GD_PNG -DUSE_GD_JPEG -DUSE_GD_WBMP -DUSE_GD_FT        -I/usr/include              maptemplate.c -o maptemplate.o
cc1: warning: changing search order for system directory "/usr/include"
cc1: warning:   as it has already been specified as a non-system directory
gcc -c -O2  -Wall -DIGNORE_MISSING_DATA  -DUSE_EPPL    -DUSE_TIFF -DUSE_JPEG -DUSE_GD_PNG -DUSE_GD_JPEG -DUSE_GD_WBMP -DUSE_GD_FT        -I/usr/include              mapbits.c -o mapbits.o
gcc -c -O2  -Wall -DIGNORE_MISSING_DATA  -DUSE_EPPL    -DUSE_TIFF -DUSE_JPEG -DUSE_GD_PNG -DUSE_GD_JPEG -DUSE_GD_WBMP -DUSE_GD_FT        -I/usr/include              maphash.c -o maphash.o
gcc -c -O2  -Wall -DIGNORE_MISSING_DATA  -DUSE_EPPL    -DUSE_TIFF -DUSE_JPEG -DUSE_GD_PNG -DUSE_GD_JPEG -DUSE_GD_WBMP -DUSE_GD_FT        -I/usr/include              mapshape.c -o mapshape.o
gcc -c -O2  -Wall -DIGNORE_MISSING_DATA  -DUSE_EPPL    -DUSE_TIFF -DUSE_JPEG -DUSE_GD_PNG -DUSE_GD_JPEG -DUSE_GD_WBMP -DUSE_GD_FT        -I/usr/include              mapxbase.c -o mapxbase.o
gcc -c -O2  -Wall -DIGNORE_MISSING_DATA  -DUSE_EPPL    -DUSE_TIFF -DUSE_JPEG -DUSE_GD_PNG -DUSE_GD_JPEG -DUSE_GD_WBMP -DUSE_GD_FT        -I/usr/include              mapparser.c -o mapparser.o
gcc -c -O2  -Wall -DIGNORE_MISSING_DATA  -DUSE_EPPL    -DUSE_TIFF -DUSE_JPEG -DUSE_GD_PNG -DUSE_GD_JPEG -DUSE_GD_WBMP -DUSE_GD_FT        -I/usr/include              maplexer.c -o maplexer.o
maplexer.c:3292: warning: `yyunput' defined but not used
gcc -c -O2  -Wall -DIGNORE_MISSING_DATA  -DUSE_EPPL    -DUSE_TIFF -DUSE_JPEG -DUSE_GD_PNG -DUSE_GD_JPEG -DUSE_GD_WBMP -DUSE_GD_FT        -I/usr/include              maptree.c -o maptree.o
gcc -c -O2  -Wall -DIGNORE_MISSING_DATA  -DUSE_EPPL    -DUSE_TIFF -DUSE_JPEG -DUSE_GD_PNG -DUSE_GD_JPEG -DUSE_GD_WBMP -DUSE_GD_FT        -I/usr/include              mapsearch.c -o mapsearch.o
gcc -c -O2  -Wall -DIGNORE_MISSING_DATA  -DUSE_EPPL    -DUSE_TIFF -DUSE_JPEG -DUSE_GD_PNG -DUSE_GD_JPEG -DUSE_GD_WBMP -DUSE_GD_FT        -I/usr/include              mapstring.c -o mapstring.o
gcc -c -O2  -Wall -DIGNORE_MISSING_DATA  -DUSE_EPPL    -DUSE_TIFF -DUSE_JPEG -DUSE_GD_PNG -DUSE_GD_JPEG -DUSE_GD_WBMP -DUSE_GD_FT        -I/usr/include              mapsymbol.c -o mapsymbol.o
gcc -c -O2  -Wall -DIGNORE_MISSING_DATA  -DUSE_EPPL    -DUSE_TIFF -DUSE_JPEG -DUSE_GD_PNG -DUSE_GD_JPEG -DUSE_GD_WBMP -DUSE_GD_FT        -I/usr/include              mapfile.c -o mapfile.o
gcc -c -O2  -Wall -DIGNORE_MISSING_DATA  -DUSE_EPPL    -DUSE_TIFF -DUSE_JPEG -DUSE_GD_PNG -DUSE_GD_JPEG -DUSE_GD_WBMP -DUSE_GD_FT        -I/usr/include              maplegend.c -o maplegend.o
gcc -c -O2  -Wall -DIGNORE_MISSING_DATA  -DUSE_EPPL    -DUSE_TIFF -DUSE_JPEG -DUSE_GD_PNG -DUSE_GD_JPEG -DUSE_GD_WBMP -DUSE_GD_FT        -I/usr/include              maputil.c -o maputil.o
gcc -c -O2  -Wall -DIGNORE_MISSING_DATA  -DUSE_EPPL    -DUSE_TIFF -DUSE_JPEG -DUSE_GD_PNG -DUSE_GD_JPEG -DUSE_GD_WBMP -DUSE_GD_FT        -I/usr/include              mapscale.c -o mapscale.o
gcc -c -O2  -Wall -DIGNORE_MISSING_DATA  -DUSE_EPPL    -DUSE_TIFF -DUSE_JPEG -DUSE_GD_PNG -DUSE_GD_JPEG -DUSE_GD_WBMP -DUSE_GD_FT        -I/usr/include              mapquery.c -o mapquery.o
gcc -c -O2  -Wall -DIGNORE_MISSING_DATA  -DUSE_EPPL    -DUSE_TIFF -DUSE_JPEG -DUSE_GD_PNG -DUSE_GD_JPEG -DUSE_GD_WBMP -DUSE_GD_FT        -I/usr/include              maplabel.c -o maplabel.o
gcc -c -O2  -Wall -DIGNORE_MISSING_DATA  -DUSE_EPPL    -DUSE_TIFF -DUSE_JPEG -DUSE_GD_PNG -DUSE_GD_JPEG -DUSE_GD_WBMP -DUSE_GD_FT        -I/usr/include              maperror.c -o maperror.o
gcc -c -O2  -Wall -DIGNORE_MISSING_DATA  -DUSE_EPPL    -DUSE_TIFF -DUSE_JPEG -DUSE_GD_PNG -DUSE_GD_JPEG -DUSE_GD_WBMP -DUSE_GD_FT        -I/usr/include              mapprimitive.c -o mapprimitive.o
mapprimitive.c: In function `msImageCartographicPolyline':
mapprimitive.c:1102: warning: unused variable `intersect_points'
mapprimitive.c:1099: warning: `last_angle' might be used uninitialized in this function
/usr/include/bits/mathinline.h: At top level:
mapprimitive.c:771: warning: `get_centroid' defined but not used
gcc -c -O2  -Wall -DIGNORE_MISSING_DATA  -DUSE_EPPL    -DUSE_TIFF -DUSE_JPEG -DUSE_GD_PNG -DUSE_GD_JPEG -DUSE_GD_WBMP -DUSE_GD_FT        -I/usr/include              mapproject.c -o mapproject.o
mapproject.c: In function `msGetEPSGProj':
mapproject.c:432: warning: return makes pointer from integer without a cast
gcc -c -O2  -Wall -DIGNORE_MISSING_DATA  -DUSE_EPPL    -DUSE_TIFF -DUSE_JPEG -DUSE_GD_PNG -DUSE_GD_JPEG -DUSE_GD_WBMP -DUSE_GD_FT        -I/usr/include              mapraster.c -o mapraster.o
gcc -c -O2  -Wall -DIGNORE_MISSING_DATA  -DUSE_EPPL    -DUSE_TIFF -DUSE_JPEG -DUSE_GD_PNG -DUSE_GD_JPEG -DUSE_GD_WBMP -DUSE_GD_FT        -I/usr/include              mapsde.c -o mapsde.o
c++ -c -O2  -Wall -DIGNORE_MISSING_DATA  -DUSE_EPPL    -DUSE_TIFF -DUSE_JPEG -DUSE_GD_PNG -DUSE_GD_JPEG -DUSE_GD_WBMP -DUSE_GD_FT        -I/usr/include              mapogr.cpp -o mapogr.o
cc1plus: warning: changing search order for system directory "/usr/include"
cc1plus: warning:   as it has already been specified as a non-system directory
gcc -c -O2  -Wall -DIGNORE_MISSING_DATA  -DUSE_EPPL    -DUSE_TIFF -DUSE_JPEG -DUSE_GD_PNG -DUSE_GD_JPEG -DUSE_GD_WBMP -DUSE_GD_FT        -I/usr/include              mappostgis.c -o mappostgis.o
gcc -c -O2  -Wall -DIGNORE_MISSING_DATA  -DUSE_EPPL    -DUSE_TIFF -DUSE_JPEG -DUSE_GD_PNG -DUSE_GD_JPEG -DUSE_GD_WBMP -DUSE_GD_FT        -I/usr/include              maplayer.c -o maplayer.o
gcc -c -O2  -Wall -DIGNORE_MISSING_DATA  -DUSE_EPPL    -DUSE_TIFF -DUSE_JPEG -DUSE_GD_PNG -DUSE_GD_JPEG -DUSE_GD_WBMP -DUSE_GD_FT        -I/usr/include              mapresample.c -o mapresample.o
mapresample.c:419: warning: `msInitApproxTransformer' defined but not used
mapresample.c:436: warning: `msFreeApproxTransformer' defined but not used
mapresample.c:447: warning: `msApproxTransformer' defined but not used
mapresample.c:551: warning: `msTransformMapToSource' defined but not used
gcc -c -O2  -Wall -DIGNORE_MISSING_DATA  -DUSE_EPPL    -DUSE_TIFF -DUSE_JPEG -DUSE_GD_PNG -DUSE_GD_JPEG -DUSE_GD_WBMP -DUSE_GD_FT        -I/usr/include              mapwms.c -o mapwms.o
maptemplate.h:16: warning: `inchesPerUnit' defined but not used
gcc -c -O2  -Wall -DIGNORE_MISSING_DATA  -DUSE_EPPL    -DUSE_TIFF -DUSE_JPEG -DUSE_GD_PNG -DUSE_GD_JPEG -DUSE_GD_WBMP -DUSE_GD_FT        -I/usr/include              mapwmslayer.c -o mapwmslayer.o
gcc -c -O2  -Wall -DIGNORE_MISSING_DATA  -DUSE_EPPL    -DUSE_TIFF -DUSE_JPEG -DUSE_GD_PNG -DUSE_GD_JPEG -DUSE_GD_WBMP -DUSE_GD_FT        -I/usr/include              maporaclespatial.c -o maporaclespatial.o
gcc -c -O2  -Wall -DIGNORE_MISSING_DATA  -DUSE_EPPL    -DUSE_TIFF -DUSE_JPEG -DUSE_GD_PNG -DUSE_GD_JPEG -DUSE_GD_WBMP -DUSE_GD_FT        -I/usr/include              mapgml.c -o mapgml.o
gcc -c -O2  -Wall -DIGNORE_MISSING_DATA  -DUSE_EPPL    -DUSE_TIFF -DUSE_JPEG -DUSE_GD_PNG -DUSE_GD_JPEG -DUSE_GD_WBMP -DUSE_GD_FT        -I/usr/include              mapprojhack.c -o mapprojhack.o
mapprojhack.c:71: warning: `ConvertProjUnitStringToMS' defined but not used
gcc -c -O2  -Wall -DIGNORE_MISSING_DATA  -DUSE_EPPL    -DUSE_TIFF -DUSE_JPEG -DUSE_GD_PNG -DUSE_GD_JPEG -DUSE_GD_WBMP -DUSE_GD_FT        -I/usr/include              mapthread.c -o mapthread.o
gcc -c -O2  -Wall -DIGNORE_MISSING_DATA  -DUSE_EPPL    -DUSE_TIFF -DUSE_JPEG -DUSE_GD_PNG -DUSE_GD_JPEG -DUSE_GD_WBMP -DUSE_GD_FT        -I/usr/include              epplib.c -o epplib.o
ar rc libmap.a maptemplate.o mapbits.o maphash.o mapshape.o mapxbase.o mapparser.o maplexer.o maptree.o mapsearch.o mapstring.o mapsymbol.o mapfile.o maplegend.o maputil.o mapscale.o mapquery.o maplabel.o maperror.o mapprimitive.o mapproject.o mapraster.o mapsde.o mapogr.o mappostgis.o maplayer.o mapresample.o mapwms.o mapwmslayer.o maporaclespatial.o mapgml.o mapprojhack.o mapthread.o epplib.o
ranlib libmap.a
gcc -c -O2  -Wall -DIGNORE_MISSING_DATA  -DUSE_EPPL    -DUSE_TIFF -DUSE_JPEG -DUSE_GD_PNG -DUSE_GD_JPEG -DUSE_GD_WBMP -DUSE_GD_FT        -I/usr/include              shp2img.c -o shp2img.o
gcc -O2  -Wall -DIGNORE_MISSING_DATA  -DUSE_EPPL    -DUSE_TIFF -DUSE_JPEG -DUSE_GD_PNG -DUSE_GD_JPEG -DUSE_GD_WBMP -DUSE_GD_FT        -I/usr/include              shp2img.o  -L. -lmap -lgd -L/usr/lib -lgd -ljpeg -lfreetype -lpng -lz  -ltiff -ljpeg -lfreetype -lpng -lz  -ljpeg          -lm   -o shp2img
./libmap.a(mapogr.o)(.eh_frame+0x11): undefined reference to `__gxx_personality_v0'
collect2: ld returned 1 exit status
--0-1437825122-1051337207=:26453--
