[Mapserver-users] Mandrake 9 mapserver install problems
Vincent Schut
schut at sarvision.com
Mon Apr 28 03:04:20 EDT 2003
Right, weekend is over :)
Mark, which versions of GDAL and PROJ have you installed?
The problem seems to be in one of these libraries...
(Look at the lines before the final error message: the line starting with 'gcc
-O2 ...' is the last given command, the lines after this are the real errors:
undefined references (usually meaning references to library functions that
unfortunately appear to be nonexistent in the library) having to do with OGR
(the vector part of GDAL) and PROJ (the reprojection library)). You might be
using old versions of one of these, while mapserver needs a newer version...
Regards,
Vincent.
On Friday 25 April 2003 15:20, Mark Balman wrote:
> Hi all
> Attached is the output from the re-run "make" command using your
> suggestion. Hope this helps.
> TIA
> Mark
> <<make_output.txt>>
______________________________________
Vincent Schut (schut at sarvision.com)
Sarvision B.V.
Wageningen, The Netherlands
www.sarvision.com
