[Mapserver-users] Mandrake 9 mapserver install problems
Babak Toloue Tehrani babak.tehrani at geosysnet.de
Sat Apr 26 15:05:27 EDT 2003
Hi I am using SuSe 8.1 and I remember an Error that looks like this but
I am  not sure.
- build and install the newest proj-4.5.5
- build and install the newest gdal-1.1.8
Build first the proj and second gdal. Use the same compiler.
Hope that helps,
Babak
Am Fre, 2003-04-25 um 15.20 schrieb Mark Balman:
> Hi all
> Attached is the output from the re-run "make" command using your suggestion.
> Hope this helps.
> TIA
> Mark
>  <<make_output.txt>>
Babak Toloue Tehrani <babak.tehrani at geosysnet.de>
