[Mapserver-users] Mandrake 9 mapserver install problems
Mark Balman
Mark.Balman at birdlife.org.uk
Fri Apr 25 09:20:08 EDT 2003
This message is in MIME format. Since your mail reader does not understand
this format, some or all of this message may not be legible.
------_=_NextPart_000_01C30B2D.64AB07F0
Content-Type: text/plain;
charset="iso-8859-1"
Hi all
Attached is the output from the re-run "make" command using your suggestion.
Hope this helps.
TIA
Mark
<<make_output.txt>>
name="make_output.txt"
Content-Transfer-Encoding: quoted-printable
Content-Disposition: attachment;
filename="make_output.txt"
gcc -c -O2 -Wall -DIGNORE_MISSING_DATA -DUSE_EPPL -DUSE_PROJ =
-DUSE_PROJ_API_H -DUSE_WMS -DUSE_TIFF -DUSE_JPEG -DUSE_GD_PNG =
-DUSE_GD_JPEG -DUSE_GD_WBMP -DUSE_GD_FT -DUSE_GDAL -I/usr/include =
-I/usr/local/include maptemplate.c -o maptemplate.o=0A=
cc1: warning: changing search order for system directory =
"/usr/local/include"=0A=
cc1: warning: as it has already been specified as a non-system =
directory=0A=
"/usr/include"=0A=
directory=0A=
In file included from map.h:41,=0A=
from maptemplate.h:8,=0A=
from maptemplate.c:3:=0A=
/usr/include/regex.h:535:1: warning: "__restrict_arr" redefined=0A=
In file included from /usr/include/features.h:283,=0A=
from /usr/include/stdio.h:28,=0A=
from map.h:8,=0A=
/usr/include/sys/cdefs.h:212:1: warning: this is the location of the =
previous definition=0A=
-I/usr/local/include mapbits.c -o mapbits.o=0A=
directory=0A=
"/usr/include"=0A=
directory=0A=
from mapbits.c:1:=0A=
from map.h:8,=0A=
-I/usr/local/include maphash.c -o maphash.o=0A=
directory=0A=
"/usr/include"=0A=
directory=0A=
from maphash.c:3:=0A=
from /usr/include/ctype.h:26,=0A=
from maphash.c:1:=0A=
-I/usr/local/include mapshape.c -o mapshape.o=0A=
directory=0A=
"/usr/include"=0A=
directory=0A=
from mapshape.c:8:=0A=
from map.h:8,=0A=
-I/usr/local/include mapxbase.c -o mapxbase.o=0A=
directory=0A=
"/usr/include"=0A=
directory=0A=
from mapxbase.c:8:=0A=
from map.h:8,=0A=
-I/usr/local/include mapparser.c -o mapparser.o=0A=
directory=0A=
"/usr/include"=0A=
directory=0A=
from mapparser.y:14:=0A=
from mapparser.y:9:=0A=
-I/usr/local/include maplexer.c -o maplexer.o=0A=
directory=0A=
"/usr/include"=0A=
directory=0A=
from maplexer.l:9:=0A=
from maplexer.c:30:=0A=
maplexer.c:3292: warning: `yyunput' defined but not used=0A=
-I/usr/local/include maptree.c -o maptree.o=0A=
directory=0A=
"/usr/include"=0A=
directory=0A=
from maptree.c:6:=0A=
from map.h:8,=0A=
-I/usr/local/include mapsearch.c -o mapsearch.o=0A=
directory=0A=
"/usr/include"=0A=
cc1: warning: as it has already been specified as a non-system directo=
ry=0A=
from mapsearch.c:1:=0A=
from map.h:8,=0A=
-I/usr/local/include mapstring.c -o mapstring.o=0A=
directory=0A=
"/usr/include"=0A=
directory=0A=
from mapstring.c:1:=0A=
from map.h:8,=0A=
-I/usr/local/include mapsymbol.c -o mapsymbol.o=0A=
directory=0A=
"/usr/include"=0A=
directory=0A=
from mapsymbol.c:3:=0A=
from map.h:8,=0A=
-I/usr/local/include mapfile.c -o mapfile.o=0A=
directory=0A=
"/usr/include"=0A=
directory=0A=
from mapfile.c:5:=0A=
from /usr/include/assert.h:36,=0A=
from mapfile.c:2:=0A=
-I/usr/local/include maplegend.c -o maplegend.o=0A=
directory=0A=
"/usr/include"=0A=
directory=0A=
from maplegend.c:1:=0A=
from map.h:8,=0A=
-I/usr/local/include maputil.c -o maputil.o=0A=
directory=0A=
"/usr/include"=0A=
directory=0A=
from maputil.c:1:=0A=
from map.h:8,=0A=
-I/usr/local/include mapscale.c -o mapscale.o=0A=
directory=0A=
"/usr/include"=0A=
directory=0A=
from mapscale.c:1:=0A=
from map.h:8,=0A=
-I/usr/local/include mapquery.c -o mapquery.o=0A=
directory=0A=
"/usr/include"=0A=
directory=0A=
from mapquery.c:1:=0A=
from map.h:8,=0A=
-I/usr/local/include maplabel.c -o maplabel.o=0A=
directory=0A=
"/usr/include"=0A=
directory=0A=
from maplabel.c:10:=0A=
from /usr/include/gd.h:24,=0A=
from /usr/include/gdfonts.h:19,=0A=
from maplabel.c:4:=0A=
-I/usr/local/include maperror.c -o maperror.o=0A=
directory=0A=
"/usr/include"=0A=
directory=0A=
from maperror.c:1:=0A=
from map.h:8,=0A=
-I/usr/local/include mapprimitive.c -o mapprimitive.o=0A=
directory=0A=
"/usr/include"=0A=
directory=0A=
from mapprimitive.c:1:=0A=
from map.h:8,=0A=
mapprimitive.c: In function `msImageCartographicPolyline':=0A=
mapprimitive.c:1102: warning: unused variable `intersect_points'=0A=
mapprimitive.c:1099: warning: `last_angle' might be used uninitialized =
in this function=0A=
/usr/include/bits/mathinline.h: At top level:=0A=
mapprimitive.c:771: warning: `get_centroid' defined but not used=0A=
-I/usr/local/include mapproject.c -o mapproject.o=0A=
directory=0A=
"/usr/include"=0A=
directory=0A=
from mapproject.c:1:=0A=
from map.h:8,=0A=
-I/usr/local/include mapraster.c -o mapraster.o=0A=
directory=0A=
"/usr/include"=0A=
directory=0A=
from mapraster.c:1:=0A=
from map.h:8,=0A=
-I/usr/local/include mapsde.c -o mapsde.o=0A=
directory=0A=
"/usr/include"=0A=
directory=0A=
from mapsde.c:3:=0A=
from /usr/include/time.h:28,=0A=
from mapsde.c:1:=0A=
g++ -c -O2 -Wall -DIGNORE_MISSING_DATA -DUSE_EPPL -DUSE_PROJ =
-I/usr/local/include mapogr.cpp -o mapogr.o=0A=
cc1plus: warning: changing search order for system directory =
cc1plus: warning: as it has already been specified as a non-system =
directory=0A=
"/usr/include"=0A=
directory=0A=
-I/usr/local/include mappostgis.c -o mappostgis.o=0A=
directory=0A=
"/usr/include"=0A=
directory=0A=
from mappostgis.c:1:=0A=
from map.h:8,=0A=
-I/usr/local/include maplayer.c -o maplayer.o=0A=
directory=0A=
"/usr/include"=0A=
directory=0A=
from maplayer.c:1:=0A=
from map.h:8,=0A=
-I/usr/local/include mapresample.c -o mapresample.o=0A=
directory=0A=
"/usr/include"=0A=
directory=0A=
from mapresample.h:40,=0A=
from mapresample.c:104:=0A=
from mapresample.c:103:=0A=
-I/usr/local/include mapwms.c -o mapwms.o=0A=
directory=0A=
"/usr/include"=0A=
directory=0A=
from mapwms.c:3:=0A=
from map.h:8,=0A=
-I/usr/local/include mapwmslayer.c -o mapwmslayer.o=0A=
directory=0A=
"/usr/include"=0A=
directory=0A=
from mapwmslayer.c:108:=0A=
from map.h:8,=0A=
-I/usr/local/include maporaclespatial.c -o =
maporaclespatial.o=0A=
directory=0A=
"/usr/include"=0A=
directory=0A=
from maporaclespatial.c:64:=0A=
from map.h:8,=0A=
-I/usr/local/include mapgml.c -o mapgml.o=0A=
directory=0A=
"/usr/include"=0A=
directory=0A=
from mapgml.c:1:=0A=
from map.h:8,=0A=
-I/usr/local/include mapprojhack.c -o mapprojhack.o=0A=
directory=0A=
"/usr/include"=0A=
directory=0A=
-I/usr/local/include mapthread.c -o mapthread.o=0A=
directory=0A=
"/usr/include"=0A=
directory=0A=
from mapthread.c:149:=0A=
from mapthread.c:148:=0A=
-I/usr/local/include epplib.c -o epplib.o=0A=
directory=0A=
"/usr/include"=0A=
directory=0A=
from epplib.c:6:=0A=
from epplib.c:1:=0A=
ar rc libmap.a maptemplate.o mapbits.o maphash.o mapshape.o mapxbase.o =
mapparser.o maplexer.o maptree.o mapsearch.o mapstring.o mapsymbol.o =
mapfile.o maplegend.o maputil.o mapscale.o mapquery.o maplabel.o =
maperror.o mapprimitive.o mapproject.o mapraster.o mapsde.o mapogr.o =
mappostgis.o maplayer.o mapresample.o mapwms.o mapwmslayer.o =
maporaclespatial.o mapgml.o mapprojhack.o mapthread.o epplib.o =0A=
ranlib libmap.a=0A=
-I/usr/local/include shp2img.c -o shp2img.o=0A=
directory=0A=
"/usr/include"=0A=
directory=0A=
from shp2img.c:1:=0A=
from map.h:8,=0A=
gcc -O2 -Wall -DIGNORE_MISSING_DATA -DUSE_EPPL -DUSE_PROJ =
-I/usr/local/include shp2img.o -L. -lmap -lgd -L/usr/lib =
-lgd -ljpeg -lfreetype -lpng -lz -ltiff -ljpeg -lfreetype -lpng -lz =
-lproj -ljpeg -L/usr/local/lib -lgdal.1.1 -lm -o shp2img=0A=
./libmap.a(mapogr.o): In function `msLoadWKTProjectionString':=0A=
mapogr.o(.text+0x6d): undefined reference to =
`OGRSpatialReference::IsLocal() const'=0A=
mapogr.o(.text+0x97): undefined reference to =
`OGRSpatialReference::exportToProj4(char**) const'=0A=
./libmap.a(mapogr.o): In function =
`msOGRSpatialRef2ProjectionObj(OGRSpatialReference*, =
projectionObj*)':=0A=
mapogr.o(.text+0x18d): undefined reference to =
mapogr.o(.text+0x1a7): undefined reference to =
collect2: ld returned 1 exit status=0A=
make: *** [shp2img] Error 1=0A=
------_=_NextPart_000_01C30B2D.64AB07F0--
